[Swift-devel] hang checker fun
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Mar 27 19:11:35 CDT 2011
That would be the maybe not. The hang checker already checks if jobs are
running.
It seems that the submission fails in execute2 for unknown reasons and
is retried 3 times. Then it hangs quietly instead of logging
"END_FAILURE". Which is very odd. Can you point me to your exact
installation of swift and configuration files?
Mihael
On Sun, 2011-03-27 at 16:54 -0700, Mihael Hategan wrote:
> Maybe. Maybe not. It may be that the job itself doesn't get queued.
> On Sun, 2011-03-27 at 16:41 -0700, Mihael Hategan wrote:
> > Ok. The fact that the hang checker kicks in doesn't mean that there is
> > necessarily a hang. What I see from the log is that extract is trying to
> > run and is probably just queued.
> > I will try to change the hang checker to not kick in if there is at
> > least one job running.
> > Mihael
> > On Sun, 2011-03-27 at 18:29 -0500, Allan Espinosa wrote:
> > > Here you go. (see attached)
> > > -Allan
> > > 2011/3/27 Mihael Hategan <hategan at mcs.anl.gov>:
> > > > May I also see the log? It looks like there's something weird around
> > > > line 186.
> > > > Mihael
> > > > On Sun, 2011-03-27 at 17:56 -0500, Allan Espinosa wrote:
> > > >> oops. trimmed the first part.
> > > >> Thanks
> > > >> type SgtDim;
> > > >> type Variation;
> > > >> type Seismogram;
> > > >> type PeakValue;
> > > >> type Station {
> > > >>   string name;
> > > >>   float lat;
> > > >>   float lon;
> > > >>   int erf;
> > > >>   int variation_scenario;
> > > >> type Sgt {
> > > >>   SgtDim x;
> > > >>   SgtDim y;
> > > >> type Rupture {
> > > >>   int source;
> > > >>   int index;
> > > >>   int size;
> > > >> /* some constants used by the apps*/
> > > >> global int num_time_steps = 3000;
> > > >> global string spectra_period1 = "all";
> > > >> global float filter_highhz = 5.0;
> > > >> global float simulation_timeskip = 0.1;
> > > >> app (Sgt _ext) extract(Sgt _sgt, Station _stat, Variation _var) {
> > > >>   extract @strcat("stat=", _stat.name) "extract_sgt=1"
> > > >>       @strcat("slon=", _stat.lon) @strcat("slat=", _stat.lat)
> > > >>       @strcat("rupmodfile=", @filename(_var))
> > > >>       @strcat("sgt_xfile=", @filename(_sgt.x))
> > > >>       @strcat("sgt_yfile=", @filename(_sgt.y))
> > > >>       @strcat("extract_sgt_xfile=", @filename(_ext.x))
> > > >>       @strcat("extract_sgt_yfile=", @filename(_ext.y));
> > > >> app (Seismogram _seis, PeakValue _peak)
> > > >>     seispeak(Sgt _sgt, Variation _var, Station _stat) {
> > > >>   seispeak
> > > >>       /* Args of seismogram synthesis     */
> > > >>       @strcat("stat=", _stat.name) "extract_sgt=0"
> > > >>       "outputBinary=1" "mergeOutput=1" @strcat("ntout=", num_time_steps)
> > > >>       @strcat("seis_file=", @filename(_seis))
> > > >>       /* Args of peak ground acceleration */
> > > >>       "simulation_out_pointsX=2" "simulation_out_pointsY=1"
> > > >>       "surfseis_rspectra_seismogram_units=cmpersec"
> > > >>       "surfseis_rspectra_output_units=cmpersec2"
> > > >>       "surfseis_rspectra_output_type=aa"
> > > >>       "surfseis_rspectra_apply_byteswap=no"
> > > >>       @strcat("simulation_out_timesamples=", num_time_steps)
> > > >>       @strcat("simulation_out_timeskip=", simulation_timeskip)
> > > >>       @strcat("surfseis_rspectra_period=", spectra_period1)
> > > >>       @strcat(" surfseis_rspectra_apply_filter_highHZ=", filter_highhz)
> > > >>       @strcat("in=", @filename(_seis))
> > > >>       @strcat("out=", @filename(_peak));
> > > >>     seispeak_local(Sgt _sgt, Variation _var, Station _stat) {
> > > >>   seispeak_local
> > > >> app (Seismogram _seis[], PeakValue _peak[])
> > > >>     seispeak_agg(Sgt _sgt, Variation _var[], Station _stat, int n) {
> > > >>   seispeak_agg
> > > >>       /* System args */
> > > >>       _stat.name _stat.lon _stat.lat num_time_steps
> > > >>       num_time_steps simulation_timeskip spectra_period1 filter_highhz
> > > >>       @filename(_sgt.x) @filename(_sgt.y)
> > > >>       n @filenames(_var) @filenames(_seis) @filenames(_peak);
> > > >> // Auxillary functions for the mappers
> > > >> type StationFile;
> > > >> app (StationFile _stat) getsite_file(int _run_id) {
> > > >>   getsite _run_id stdout=@filename(_stat);
> > > >> (Station _stat) get_site(int _run_id) {
> > > >>   StationFile file<"/var/tmp/site_tmp">;
> > > >>   /*file = getsite_file(_run_id);*/
> > > >>   _stat = readData(file);
> > > >> type RuptureFile;
> > > >> app (RuptureFile _rup) getrupture_file(int _run_id) {
> > > >>   getrupture _run_id stdout=@filename(_rup);
> > > >> (Rupture _rup[]) get_ruptures(int _run_id, Station _site) {
> > > >>   /*RuptureFile file<single_file_mapper; file=@strcat(_site.name,
> > > >> "/rup_tmp")>;*/
> > > >>   RuptureFile file<"LGU/rup_tmp">;
> > > >>   /*file = getrupture_file(_run_id);*/
> > > >>   _rup = readData(file);
> > > >> type VariationFile;
> > > >> app (VariationFile _var) getvariation_file(Station _site, Rupture _rup,
> > > >>     string _loc) {
> > > >>   variation_mapper "-e" _site.erf "-v" _site.variation_scenario
> > > >>       "-l" _loc "-s" _rup.source "-r" _rup.index stdout=@_var;
> > > >> (string _vars[]) get_variations(Station _site, Rupture _rup, string _loc){
> > > >>   string fname = @strcat(_rup.source, "_", _rup.index);
> > > >>   VariationFile file<single_file_mapper;
> > > >>       file=@strcat(_site.name, "/varlist/", _rup.source, "/", fname, ".txt")>;
> > > >>   /*file = getvariation_file(_site, _rup, _loc);*/
> > > >>   _vars = readData(file);
> > > >> type offset {
> > > >>   int off;
> > > >>   int size;
> > > >> type offset_file;
> > > >> (offset _off[]) mkoffset(int _size, int _group_size) {
> > > >>    offset_file file <single_file_mapper; file=@strcat("LGU/offset-",_size)>;
> > > >>    file = mkoffset_file(_size, _group_size);
> > > >>    _off = readData(file);
> > > >> app (offset_file _off) mkoffset_file(int _size, int _group_size) {
> > > >>   mkoffset _size _group_size;
> > > >> /* TODO: data management zip jobs */
> > > >> /* Main program */
> > > >> int run_id = 664;
> > > >> int agg_size = 80;
> > > >> int loc_size = 20;
> > > >> string datadir =
> > > >>   "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results";
> > > >> Station site = get_site(run_id);
> > > >> Sgt sgt_var <ext; exec="getsgtvar.rb", r=run_id, s=site.name,
> > > >>   l="gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/SgtFiles">;
> > > >> Rupture rups[] = get_ruptures(run_id, site);
> > > >> foreach rup in rups {
> > > >>   string loc_sub = @strcat(datadir, "/", site.name, "/", rup.source,
> > > >> "/", rup.index);
> > > >>   Sgt sub <ext; exec="getsub.rb", l=loc_sub, n=site.name, s=rup.source,
> > > >>       r=rup.index>;
> > > >>   string var_str[] = get_variations( site, rup,
> > > >>       "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations"
> > > >>   Variation vars[] <array_mapper; files=var_str>;
> > > >>   sub = extract(sgt_var,  site, vars[rup.size-1]);
> > > >>   string seis_str[];
> > > >>   string peak_str[];
> > > >>   foreach var,i in vars {
> > > >>     seis_str[i] = @strcat(loc_sub, "/Seismogram_", site.name, "_", rup.source,
> > > >>                           "_", rup.index, "_", i, ".grm");
> > > >>     peak_str[i] = @strcat(loc_sub, "/PeakVals_", site.name, "_", rup.source,
> > > >>                           "_", rup.index, "_", i, ".bsa");
> > > >>   Seismogram seis[] <array_mapper; files=seis_str>;
> > > >>   PeakValue  peak[] <array_mapper; files=peak_str>;
> > > >>   if(rup.size <= loc_size) {
> > > >>      * Not worth to transfer the data. Execute on TeraGrid instead.
> > > >>      * Also execute on localhost.
> > > >>       (seis[i], peak[i]) = seispeak_local(sub, var, site);
> > > >>   } else {if(rup.size <= agg_size) {
> > > >>     /* Execute on a single resource */
> > > >>     (seis, peak) = seispeak_agg(sub, vars, site, rup.size);
> > > >>   } else {
> > > >>     /*offset offs[] = mkoffset(rup.size, agg_size);*/
> > > >>     /*for i in offs {*/
> > > >>       /*(seis, peak) = seispeak_agg(sub, vars[i.off:i.off+off.size],*/
> > > >>                                   /*off.size);*/
> > > >> > I don't believe you. There is no SgtDim data type in that script.
> > > >> > Mihael
> > > >> > On Sun, 2011-03-27 at 16:55 -0500, Allan Espinosa wrote:
> > > >> >> Here it is.  The get_app() calls are simple wrappers to readData()
> > > >> >> type offset {
> > > >> >>   int off;
> > > >> >>   int size;
> > > >> >> type offset_file;
> > > >> >> /* Main program */
> > > >> >> int run_id = 664;
> > > >> >> int agg_size = 80;
> > > >> >> int loc_size = 20;
> > > >> >> string datadir =
> > > >> >> "/", rup.index);
> > > >> >>       r=rup.index>;
> > > >> >>   string seis_str[];
> > > >> >>   string peak_str[];
> > > >> >>   } else {
> > > >> >>     /*for i in offs {*/
> > > >> >>                                   /*off.size);*/
> > > >> >> > May I see the script?
> > > >> >> > On Fri, 2011-03-25 at 19:42 -0500, Allan Espinosa wrote:
> > > >> >> >> this has been occurring for 70 times already.  What i expect is for
> > > >> >> >> the app with SgtDim sub to run and close the future.
> > > >> >> >> 2011-03-25 19:40:12,217-0500 WARN  HangChecker No events in 10s.
> > > >> >> >> Registered futures:
> > > >> >> >> Rupture[] rups  Closed, 1 elements, 0 listeners
> > > >> >> >> Variation vars - Closed, no listeners
> > > >> >> >> SgtDim sub - Open, 1 listeners
> > > >> >> >> string site  Closed, no listeners
> > > >> >> >> Variation[] vars  Closed, 72 elements, 0 listeners
> > > >> >> >> Waiting threads:
> > > >> >> >> 0-13
> > > >> >> >> 0-13-0-7
> > > >> >> >> 0-13-0-8-1-1
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
