[Swift-devel] hanging problem
    Jonathan Monette
    jon.monette at gmail.com
    Sun Mar 27 20:59:01 CDT 2011
By simply changing foreach img, i in stats to foreach img, i in diff_imgs I
get the output below.
RunID: 20110327-2014-gnzxh45g
 (input): found 10 files
Progress:  time:0
original callback URI is http://169.254.95.119:44421
callback URI has been overridden to http://192.5.86.6:44421
Adjusting buffer size to 786432
Adjusting buffer size to 524288
Adjusting buffer size to 314368
Progress:  time:6284  Submitted:9  Active:1
Adjusting buffer size to 224256
Progress:  time:7346  Submitted:2  Active:8
Adjusting buffer size to 156672
Progress:  time:8894  Active:2  Checking status:1  Finished successfully:7
Progress:  time:9907  Submitted:16  Active:2  Finished successfully:12
[org.griphyn.vdl.mapping.DataNode identifier
dataset:20110327-2014-u3tv8xt3:720000000630 type Status with no value at
dataset=stats path=[0] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000636 type Status with no
value at dataset=stats path=[1] (not
closed),org.griphyn.vdl.mapping.DataNode identifier
dataset:20110327-2014-u3tv8xt3:720000000621 type Status with no value at
dataset=stats path=[2] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000600 type Status with no
value at dataset=stats path=[3] (not
dataset:20110327-2014-u3tv8xt3:720000000606 type Status with no value at
dataset=stats path=[4] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000609 type Status with no
value at dataset=stats path=[5] (not
dataset:20110327-2014-u3tv8xt3:720000000603 type Status with no value at
dataset=stats path=[6] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000618 type Status with no
value at dataset=stats path=[7] (not
dataset:20110327-2014-u3tv8xt3:720000000627 type Status with no value at
dataset=stats path=[8] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000639 type Status with no
value at dataset=stats path=[9] (not
dataset:20110327-2014-u3tv8xt3:720000000643 type Status with no value at
dataset=stats path=[10] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000597 type Status with no
value at dataset=stats path=[11] (not
dataset:20110327-2014-u3tv8xt3:720000000642 type Status with no value at
dataset=stats path=[12] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000624 type Status with no
value at dataset=stats path=[13] (not
dataset:20110327-2014-u3tv8xt3:720000000633 type Status with no value at
dataset=stats path=[14] (not closed),org.griphyn.vdl.mapping.DataNode
identifier dataset:20110327-2014-u3tv8xt3:720000000612 type Status with no
value at dataset=stats path=[15] (not
dataset:20110327-2014-u3tv8xt3:720000000615 type Status with no value at
dataset=stats path=[16] (not closed)]
Progress:  time:11194  Submitted:24  Active:9  Checking status:1  Finished
successfully:30
The cache already contains
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000006.000009.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000000.000005.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000006.000007.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000002.000007.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000007.000008.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000001.000008.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000000.000006.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000001.000002.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000000.000004.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000004.000005.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000003.000004.fits.
Progress:  time:12197  Stage in:1  Submitted:10  Active:6  Finished
successfully:46 Failed but can retry:1
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000006.000008.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000002.000008.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000008.000009.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000000.000003.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000000.000009.fits.
pads:m101_montage-20110327-2014-gnzxh45g/shared/stat_dir/stat.diff.000005.000006.fits.
Progress:  time:13207  Submitted:1  Active:6  Checking status:1  Finished
successfully:47 Failed but can retry:9
No events in 10s.
Badness
Registered futures:
Image diff_img - Closed, no listeners
Image proj_img - Closed, no listeners
Table corrections_tbl - Open, 1 listeners
Image[] corrected_images  Open, 1 listeners
Table fits_images_tbl - Open, 1 listeners
Table difference_tbl - Closed, no listeners
BackgroundStruct[] back_struct  Open, 0 elements, 1 listeners
Status stats - Closed, no listeners
Status[] stats  Closed, no listeners
Image[] projected_images  Closed, no listeners
Image[] difference_images  Closed, no listeners
Image corrected_mos - Open, 1 listeners
Table status_tbl - Closed, no listeners
Table back_list - Open, 1 listeners
DiffStruct[] diffs  Closed, 17 elements, 0 listeners
string swift#mapper#17028  Closed, no listeners
Image proj_1 - Closed, no listeners
Table images_tbl - Closed, no listeners
Waiting threads:
0-8-1
0-6-3
0-9
0-8-2
0-10
0-8-0
0-7
0-5-2
Progress:  time:30007  Finished successfully:47 Failed but can retry:17
No events in 10s.
Badness
Registered futures:
Waiting threads:
0-8-1
0-6-3
0-9
0-8-2
0-10
0-8-0
0-7
0-5-2
What does it mean that something is in the cache?
On Sun, Mar 27, 2011 at 8:16 PM, Jonathan Monette <jon.monette at gmail.com>wrote:
> Ok.  I understand.
> On Sun, Mar 27, 2011 at 8:13 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
>> Let me be clear. I don't think that's your problem. That is simply a
>> matter of, perhaps, style. I found it unclear. It doesn't say what it
>> does.
>> On Sun, 2011-03-27 at 20:10 -0500, Jonathan Monette wrote:
>> > This makes sense syntactically but I am guessing the internal logic
>> > does not like this so is this something that Swift shouldn't  do or
>> > something that Swift should do but is just broken?
>> > On Sun, Mar 27, 2011 at 8:05 PM, Jonathan Monette
>> > <jon.monette at gmail.com> wrote:
>> >         Yea.  I use the foreach loop because I need to iterate through
>> >         the diff_imgs array and run an app on each of the entries.
>> >          The loop runs and completes and all the files in stats are
>> >         mapped and have data they are just not being closed.  So is
>> >         there a better way of accomplishing what I am doing in Swift?
>> >         On Sun, Mar 27, 2011 at 8:02 PM, Daniel S. Katz
>> >         <dsk at ci.uchicago.edu> wrote:
>> >                 Can you suggest how this should be done?
>> >                 Dan
>> >                 On Mar 27, 2011, at 8:00 PM, Mihael Hategan wrote:
>> >                 > Well, you seem to be iterating over an array that
>> >                 you are trying to
>> >                 > build inside the iteration, and you are not doing a
>> >                 fold. It's somewhat
>> >                 > coincidental that it works, probably because stats
>> >                 is mapped by a static
>> >                 > mapper and you don't actually use the value ("img").
>> >                 > Though I see what you are trying to do. And it
>> >                 should either work or
>> >                 > fail nicely. So I'll see if I can make a simple test
>> >                 case out of this.
>> >                 > Mihael
>> >                 > On Sun, 2011-03-27 at 19:43 -0500, Jonathan Monette
>> >                 wrote:
>> >                 >> stats is an array mapped to several files in a
>> >                 directory of metadata
>> >                 >> generated by mFitplane.  I need to pass all these
>> >                 files and another
>> >                 >> metadata file to mConcatFit which is the app after
>> >                 this foreach loop.
>> >                 >> I need to wait for the foreach loop to be complete
>> >                 before mConcatFit
>> >                 >> can run.
>> >                 >> On Sun, Mar 27, 2011 at 7:41 PM, Mihael Hategan
>> >                 >> wrote:
>> >                 >>        You have:
>> >                 >>               stats[ i ] = mFitplane
>> >                 ( diff_imgs[i] );
>> >                 >>        What is it that you are trying to do there?
>> >                 >>        Mihael
>> >                 >>        On Sun, 2011-03-27 at 15:54 -0500, Jonathan
>> >                 Monette wrote:
>> >                 >>> here is my entire script
>> >                 >>> On Sun, Mar 27, 2011 at 3:45 PM, Mihael Hategan
>> >                 >>> wrote:
>> >                 >>>        On Wed, 2011-03-23 at 16:31 -0500, Jonathan
>> >                 Monette
>> >                 >>        wrote:
>> >                 >>>> How can the array be closed but all of its values
>> >                 >>        not be?
>> >                 >>>        The array being closed simply means that
>> >                 its size is
>> >                 >>        known,
>> >                 >>>        but not
>> >                 >>>        necessarily that its elements have all been
>> >                 >>        computed.
>> >                 >>>        I'll look at the log, but I'd also like the
>> >                 entire
>> >                 >>        script.
>> >                 >>>        Mihael
>> >                 >>> Any intelligent fool can make things bigger and
>> >                 more
>> >                 >>        complex... It
>> >                 >>> takes a touch of genius - and a lot of courage to
>> >                 move in
>> >                 >>        the opposite
>> >                 >>> direction.
>> >                 >>> - Albert Einstein
>> >                 more complex... It
>> >                 move in the opposite
>> >                 >> direction.
>> >                 >> - Albert Einstein
>> >                 > _______________________________________________
>> >                 > Swift-devel mailing list
>> >                 > Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> >                 Daniel S. Katz
>> >                 University of Chicago
>> >                 (773) 834-7186 (voice)
>> >                 (773) 834-3700 (fax)
>> >                 d.katz at ieee.org or dsk at ci.uchicago.edu
>> >                 http://www.ci.uchicago.edu/~dsk/
>> >         Any intelligent fool can make things bigger and more
>> >         complex... It takes a touch of genius - and a lot of courage
>> >         to move in the opposite direction.
>> >         - Albert Einstein
>> > Any intelligent fool can make things bigger and more complex... It
>> > takes a touch of genius - and a lot of courage to move in the opposite
>> > direction.
>> > - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It takes a
> touch of genius - and a lot of courage to move in the opposite direction.
> - Albert Einstein
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110327/38737936/attachment.html>
