[Swift-devel] hanging problem
Jonathan Monette
jon.monette at gmail.com
Sun Mar 27 20:16:48 CDT 2011
Ok. I understand.
On Sun, Mar 27, 2011 at 8:13 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Let me be clear. I don't think that's your problem. That is simply a
> matter of, perhaps, style. I found it unclear. It doesn't say what it
> does.
> On Sun, 2011-03-27 at 20:10 -0500, Jonathan Monette wrote:
> > This makes sense syntactically but I am guessing the internal logic
> > does not like this so is this something that Swift shouldn't do or
> > something that Swift should do but is just broken?
> > On Sun, Mar 27, 2011 at 8:05 PM, Jonathan Monette
> > <jon.monette at gmail.com> wrote:
> > Yea. I use the foreach loop because I need to iterate through
> > the diff_imgs array and run an app on each of the entries.
> > The loop runs and completes and all the files in stats are
> > mapped and have data they are just not being closed. So is
> > there a better way of accomplishing what I am doing in Swift?
> > On Sun, Mar 27, 2011 at 8:02 PM, Daniel S. Katz
> > <dsk at ci.uchicago.edu> wrote:
> > Can you suggest how this should be done?
> > Dan
> > On Mar 27, 2011, at 8:00 PM, Mihael Hategan wrote:
> > > Well, you seem to be iterating over an array that
> > you are trying to
> > > build inside the iteration, and you are not doing a
> > fold. It's somewhat
> > > coincidental that it works, probably because stats
> > is mapped by a static
> > > mapper and you don't actually use the value ("img").
> > > Though I see what you are trying to do. And it
> > should either work or
> > > fail nicely. So I'll see if I can make a simple test
> > case out of this.
> > > Mihael
> > > On Sun, 2011-03-27 at 19:43 -0500, Jonathan Monette
> > wrote:
> > >> stats is an array mapped to several files in a
> > directory of metadata
> > >> generated by mFitplane. I need to pass all these
> > files and another
> > >> metadata file to mConcatFit which is the app after
> > this foreach loop.
> > >> I need to wait for the foreach loop to be complete
> > before mConcatFit
> > >> can run.
> > >> On Sun, Mar 27, 2011 at 7:41 PM, Mihael Hategan
> > >> wrote:
> > >> You have:
> > >> foreach img, i in stats
> > >> stats[ i ] = mFitplane
> > ( diff_imgs[i] );
> > >> What is it that you are trying to do there?
> > >> Mihael
> > >> On Sun, 2011-03-27 at 15:54 -0500, Jonathan
> > Monette wrote:
> > >>> here is my entire script
> > >>> On Sun, Mar 27, 2011 at 3:45 PM, Mihael Hategan
> > >>> wrote:
> > >>> On Wed, 2011-03-23 at 16:31 -0500, Jonathan
> > Monette
> > >> wrote:
> > >>>> How can the array be closed but all of its values
> > >> not be?
> > >>> The array being closed simply means that
> > its size is
> > >> known,
> > >>> but not
> > >>> necessarily that its elements have all been
> > >> computed.
> > >>> I'll look at the log, but I'd also like the
> > entire
> > >> script.
> > >>> Mihael
> > >>> Any intelligent fool can make things bigger and
> > more
> > >> complex... It
> > >>> takes a touch of genius - and a lot of courage to
> > move in
> > >> the opposite
> > >>> direction.
> > >>> - Albert Einstein
> > more complex... It
> > move in the opposite
> > >> direction.
> > >> - Albert Einstein
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Daniel S. Katz
> > University of Chicago
> > (773) 834-7186 (voice)
> > (773) 834-3700 (fax)
> > d.katz at ieee.org or dsk at ci.uchicago.edu
> > http://www.ci.uchicago.edu/~dsk/
> > Any intelligent fool can make things bigger and more
> > complex... It takes a touch of genius - and a lot of courage
> > to move in the opposite direction.
> > - Albert Einstein
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110327/b3cf84e7/attachment.html>
