[Swift-devel] hanging problem
    Daniel S. Katz
    dsk at ci.uchicago.edu
    Sun Mar 27 20:02:56 CDT 2011
Can you suggest how this should be done?
Dan
On Mar 27, 2011, at 8:00 PM, Mihael Hategan wrote:
> Well, you seem to be iterating over an array that you are trying to
> build inside the iteration, and you are not doing a fold. It's somewhat
> coincidental that it works, probably because stats is mapped by a static
> mapper and you don't actually use the value ("img").
> Though I see what you are trying to do. And it should either work or
> fail nicely. So I'll see if I can make a simple test case out of this.
> Mihael
> On Sun, 2011-03-27 at 19:43 -0500, Jonathan Monette wrote:
>> stats is an array mapped to several files in a directory of metadata
>> generated by mFitplane.  I need to pass all these files and another
>> metadata file to mConcatFit which is the app after this foreach loop.
>> I need to wait for the foreach loop to be complete before mConcatFit
>> can run.
>> On Sun, Mar 27, 2011 at 7:41 PM, Mihael Hategan <hategan at mcs.anl.gov>
>> wrote:
>>        You have:
>>        foreach img, i in stats
>>               stats[ i ] = mFitplane ( diff_imgs[i] );
>>        What is it that you are trying to do there?
>>        Mihael
>>        On Sun, 2011-03-27 at 15:54 -0500, Jonathan Monette wrote:
>>> here is my entire script
>>> On Sun, Mar 27, 2011 at 3:45 PM, Mihael Hategan
>>> wrote:
>>>        On Wed, 2011-03-23 at 16:31 -0500, Jonathan Monette
>>        wrote:
>>>> How can the array be closed but all of its values
>>        not be?
>>>        The array being closed simply means that its size is
>>        known,
>>>        but not
>>>        necessarily that its elements have all been
>>        computed.
>>>        I'll look at the log, but I'd also like the entire
>>        script.
>>>        Mihael
>>> Any intelligent fool can make things bigger and more
>>        complex... It
>>> takes a touch of genius - and a lot of courage to move in
>>        the opposite
>>> direction.
>>> - Albert Einstein
>> Any intelligent fool can make things bigger and more complex... It
>> takes a touch of genius - and a lot of courage to move in the opposite
>> direction.
>> - Albert Einstein
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Daniel S. Katz
University of Chicago
(773) 834-7186 (voice)
(773) 834-3700 (fax)
d.katz at ieee.org or dsk at ci.uchicago.edu
http://www.ci.uchicago.edu/~dsk/
