[Swift-devel] hanging problem
Mihael Hategan
hategan at mcs.anl.gov
Sun Mar 27 20:00:47 CDT 2011
Well, you seem to be iterating over an array that you are trying to
build inside the iteration, and you are not doing a fold. It's somewhat
coincidental that it works, probably because stats is mapped by a static
mapper and you don't actually use the value ("img").
Though I see what you are trying to do. And it should either work or
fail nicely. So I'll see if I can make a simple test case out of this.
Mihael
On Sun, 2011-03-27 at 19:43 -0500, Jonathan Monette wrote:
> stats is an array mapped to several files in a directory of metadata
> generated by mFitplane. I need to pass all these files and another
> metadata file to mConcatFit which is the app after this foreach loop.
> I need to wait for the foreach loop to be complete before mConcatFit
> can run.
> On Sun, Mar 27, 2011 at 7:41 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> You have:
> foreach img, i in stats
> stats[ i ] = mFitplane ( diff_imgs[i] );
> What is it that you are trying to do there?
> Mihael
> On Sun, 2011-03-27 at 15:54 -0500, Jonathan Monette wrote:
> > here is my entire script
> > On Sun, Mar 27, 2011 at 3:45 PM, Mihael Hategan
> > wrote:
> > On Wed, 2011-03-23 at 16:31 -0500, Jonathan Monette
> wrote:
> > > How can the array be closed but all of its values
> not be?
> > The array being closed simply means that its size is
> known,
> > but not
> > necessarily that its elements have all been
> computed.
> > I'll look at the log, but I'd also like the entire
> script.
> > Mihael
> > Any intelligent fool can make things bigger and more
> complex... It
> > takes a touch of genius - and a lot of courage to move in
> the opposite
> > direction.
> > - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
