[Swift-devel] hang checker fun
Allan Espinosa aespinosa at cs.uchicago.edu
Sun Mar 27 18:29:30 CDT 2011
Here you go. (see attached)
-Allan
2011/3/27 Mihael Hategan <hategan at mcs.anl.gov>:
> May I also see the log? It looks like there's something weird around
> line 186.
> Mihael
> On Sun, 2011-03-27 at 17:56 -0500, Allan Espinosa wrote:
>> oops. trimmed the first part.
>> Thanks
>> type SgtDim;
>> type Variation;
>> type Seismogram;
>> type PeakValue;
>> type Station {
>>   string name;
>>   float lat;
>>   float lon;
>>   int erf;
>>   int variation_scenario;
>> type Sgt {
>>   SgtDim x;
>>   SgtDim y;
>> type Rupture {
>>   int source;
>>   int index;
>>   int size;
>> /* some constants used by the apps*/
>> global int num_time_steps = 3000;
>> global string spectra_period1 = "all";
>> global float filter_highhz = 5.0;
>> global float simulation_timeskip = 0.1;
>> app (Sgt _ext) extract(Sgt _sgt, Station _stat, Variation _var) {
>>   extract @strcat("stat=", _stat.name) "extract_sgt=1"
>>       @strcat("slon=", _stat.lon) @strcat("slat=", _stat.lat)
>>       @strcat("rupmodfile=", @filename(_var))
>>       @strcat("sgt_xfile=", @filename(_sgt.x))
>>       @strcat("sgt_yfile=", @filename(_sgt.y))
>>       @strcat("extract_sgt_xfile=", @filename(_ext.x))
>>       @strcat("extract_sgt_yfile=", @filename(_ext.y));
>> app (Seismogram _seis, PeakValue _peak)
>>     seispeak(Sgt _sgt, Variation _var, Station _stat) {
>>   seispeak
>>       /* Args of seismogram synthesis     */
>>       @strcat("stat=", _stat.name) "extract_sgt=0"
>>       "outputBinary=1" "mergeOutput=1" @strcat("ntout=", num_time_steps)
>>       @strcat("seis_file=", @filename(_seis))
>>       /* Args of peak ground acceleration */
>>       "simulation_out_pointsX=2" "simulation_out_pointsY=1"
>>       "surfseis_rspectra_seismogram_units=cmpersec"
>>       "surfseis_rspectra_output_units=cmpersec2"
>>       "surfseis_rspectra_output_type=aa"
>>       "surfseis_rspectra_apply_byteswap=no"
>>       @strcat("simulation_out_timesamples=", num_time_steps)
>>       @strcat("simulation_out_timeskip=", simulation_timeskip)
>>       @strcat("surfseis_rspectra_period=", spectra_period1)
>>       @strcat(" surfseis_rspectra_apply_filter_highHZ=", filter_highhz)
>>       @strcat("in=", @filename(_seis))
>>       @strcat("out=", @filename(_peak));
>>     seispeak_local(Sgt _sgt, Variation _var, Station _stat) {
>>   seispeak_local
>> app (Seismogram _seis[], PeakValue _peak[])
>>     seispeak_agg(Sgt _sgt, Variation _var[], Station _stat, int n) {
>>   seispeak_agg
>>       /* System args */
>>       _stat.name _stat.lon _stat.lat num_time_steps
>>       num_time_steps simulation_timeskip spectra_period1 filter_highhz
>>       @filename(_sgt.x) @filename(_sgt.y)
>>       n @filenames(_var) @filenames(_seis) @filenames(_peak);
>> // Auxillary functions for the mappers
>> type StationFile;
>> app (StationFile _stat) getsite_file(int _run_id) {
>>   getsite _run_id stdout=@filename(_stat);
>> (Station _stat) get_site(int _run_id) {
>>   StationFile file<"/var/tmp/site_tmp">;
>>   /*file = getsite_file(_run_id);*/
>>   _stat = readData(file);
>> type RuptureFile;
>> app (RuptureFile _rup) getrupture_file(int _run_id) {
>>   getrupture _run_id stdout=@filename(_rup);
>> (Rupture _rup[]) get_ruptures(int _run_id, Station _site) {
>>   /*RuptureFile file<single_file_mapper; file=@strcat(_site.name,
>> "/rup_tmp")>;*/
>>   RuptureFile file<"LGU/rup_tmp">;
>>   /*file = getrupture_file(_run_id);*/
>>   _rup = readData(file);
>> type VariationFile;
>> app (VariationFile _var) getvariation_file(Station _site, Rupture _rup,
>>     string _loc) {
>>   variation_mapper "-e" _site.erf "-v" _site.variation_scenario
>>       "-l" _loc "-s" _rup.source "-r" _rup.index stdout=@_var;
>> (string _vars[]) get_variations(Station _site, Rupture _rup, string _loc){
>>   string fname = @strcat(_rup.source, "_", _rup.index);
>>   VariationFile file<single_file_mapper;
>>       file=@strcat(_site.name, "/varlist/", _rup.source, "/", fname, ".txt")>;
>>   /*file = getvariation_file(_site, _rup, _loc);*/
>>   _vars = readData(file);
>> type offset {
>>   int off;
>>   int size;
>> type offset_file;
>> (offset _off[]) mkoffset(int _size, int _group_size) {
>>    offset_file file <single_file_mapper; file=@strcat("LGU/offset-",_size)>;
>>    file = mkoffset_file(_size, _group_size);
>>    _off = readData(file);
>> app (offset_file _off) mkoffset_file(int _size, int _group_size) {
>>   mkoffset _size _group_size;
>> /* TODO: data management zip jobs */
>> /* Main program */
>> int run_id = 664;
>> int agg_size = 80;
>> int loc_size = 20;
>> string datadir =
>>   "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results";
>> Station site = get_site(run_id);
>> Sgt sgt_var <ext; exec="getsgtvar.rb", r=run_id, s=site.name,
>>   l="gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/SgtFiles">;
>> Rupture rups[] = get_ruptures(run_id, site);
>> foreach rup in rups {
>>   string loc_sub = @strcat(datadir, "/", site.name, "/", rup.source,
>> "/", rup.index);
>>   Sgt sub <ext; exec="getsub.rb", l=loc_sub, n=site.name, s=rup.source,
>>       r=rup.index>;
>>   string var_str[] = get_variations( site, rup,
>>       "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations"
>>   Variation vars[] <array_mapper; files=var_str>;
>>   sub = extract(sgt_var,  site, vars[rup.size-1]);
>>   string seis_str[];
>>   string peak_str[];
>>   foreach var,i in vars {
>>     seis_str[i] = @strcat(loc_sub, "/Seismogram_", site.name, "_", rup.source,
>>                           "_", rup.index, "_", i, ".grm");
>>     peak_str[i] = @strcat(loc_sub, "/PeakVals_", site.name, "_", rup.source,
>>                           "_", rup.index, "_", i, ".bsa");
>>   Seismogram seis[] <array_mapper; files=seis_str>;
>>   PeakValue  peak[] <array_mapper; files=peak_str>;
>>   if(rup.size <= loc_size) {
>>      * Not worth to transfer the data. Execute on TeraGrid instead.
>>      * Also execute on localhost.
>>       (seis[i], peak[i]) = seispeak_local(sub, var, site);
>>   } else {if(rup.size <= agg_size) {
>>     /* Execute on a single resource */
>>     (seis, peak) = seispeak_agg(sub, vars, site, rup.size);
>>   } else {
>>     /*offset offs[] = mkoffset(rup.size, agg_size);*/
>>     /*for i in offs {*/
>>       /*(seis, peak) = seispeak_agg(sub, vars[i.off:i.off+off.size],*/
>>                                   /*off.size);*/
>> > I don't believe you. There is no SgtDim data type in that script.
>> > Mihael
>> > On Sun, 2011-03-27 at 16:55 -0500, Allan Espinosa wrote:
>> >> Here it is.  The get_app() calls are simple wrappers to readData()
>> >> type offset {
>> >>   int off;
>> >>   int size;
>> >> type offset_file;
>> >> /* Main program */
>> >> int run_id = 664;
>> >> int agg_size = 80;
>> >> int loc_size = 20;
>> >> string datadir =
>> >> "/", rup.index);
>> >>       r=rup.index>;
>> >>   string seis_str[];
>> >>   string peak_str[];
>> >>   } else {
>> >>     /*for i in offs {*/
>> >>                                   /*off.size);*/
>> >> > May I see the script?
>> >> > On Fri, 2011-03-25 at 19:42 -0500, Allan Espinosa wrote:
>> >> >> this has been occurring for 70 times already.  What i expect is for
>> >> >> the app with SgtDim sub to run and close the future.
>> >> >> 2011-03-25 19:40:12,217-0500 WARN  HangChecker No events in 10s.
>> >> >> Registered futures:
>> >> >> Rupture[] rups  Closed, 1 elements, 0 listeners
>> >> >> Variation vars - Closed, no listeners
>> >> >> SgtDim sub - Open, 1 listeners
>> >> >> string site  Closed, no listeners
>> >> >> Variation[] vars  Closed, 72 elements, 0 listeners
>> >> >> Waiting threads:
>> >> >> 0-13
>> >> >> 0-13-0-7
>> >> >> 0-13-0-8-1-1
Type: application/x-bzip2
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110327/c779e836/attachment.bin>
