[Swift-devel] hang checker fun
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Mar 27 18:26:41 CDT 2011
May I also see the log? It looks like there's something weird around
line 186.
Mihael
On Sun, 2011-03-27 at 17:56 -0500, Allan Espinosa wrote:
> oops. trimmed the first part.
> Thanks
> type SgtDim;
> type Variation;
> type Seismogram;
> type PeakValue;
> type Station {
>   string name;
>   float lat;
>   float lon;
>   int erf;
>   int variation_scenario;
> type Sgt {
>   SgtDim x;
>   SgtDim y;
> type Rupture {
>   int source;
>   int index;
>   int size;
> /* some constants used by the apps*/
> global int num_time_steps = 3000;
> global string spectra_period1 = "all";
> global float filter_highhz = 5.0;
> global float simulation_timeskip = 0.1;
> app (Sgt _ext) extract(Sgt _sgt, Station _stat, Variation _var) {
>   extract @strcat("stat=", _stat.name) "extract_sgt=1"
>       @strcat("slon=", _stat.lon) @strcat("slat=", _stat.lat)
>       @strcat("rupmodfile=", @filename(_var))
>       @strcat("sgt_xfile=", @filename(_sgt.x))
>       @strcat("sgt_yfile=", @filename(_sgt.y))
>       @strcat("extract_sgt_xfile=", @filename(_ext.x))
>       @strcat("extract_sgt_yfile=", @filename(_ext.y));
> app (Seismogram _seis, PeakValue _peak)
>     seispeak(Sgt _sgt, Variation _var, Station _stat) {
>   seispeak
>       /* Args of seismogram synthesis     */
>       @strcat("stat=", _stat.name) "extract_sgt=0"
>       "outputBinary=1" "mergeOutput=1" @strcat("ntout=", num_time_steps)
>       @strcat("seis_file=", @filename(_seis))
>       /* Args of peak ground acceleration */
>       "simulation_out_pointsX=2" "simulation_out_pointsY=1"
>       "surfseis_rspectra_seismogram_units=cmpersec"
>       "surfseis_rspectra_output_units=cmpersec2"
>       "surfseis_rspectra_output_type=aa"
>       "surfseis_rspectra_apply_byteswap=no"
>       @strcat("simulation_out_timesamples=", num_time_steps)
>       @strcat("simulation_out_timeskip=", simulation_timeskip)
>       @strcat("surfseis_rspectra_period=", spectra_period1)
>       @strcat(" surfseis_rspectra_apply_filter_highHZ=", filter_highhz)
>       @strcat("in=", @filename(_seis))
>       @strcat("out=", @filename(_peak));
>     seispeak_local(Sgt _sgt, Variation _var, Station _stat) {
>   seispeak_local
> app (Seismogram _seis[], PeakValue _peak[])
>     seispeak_agg(Sgt _sgt, Variation _var[], Station _stat, int n) {
>   seispeak_agg
>       /* System args */
>       _stat.name _stat.lon _stat.lat num_time_steps
>       num_time_steps simulation_timeskip spectra_period1 filter_highhz
>       @filename(_sgt.x) @filename(_sgt.y)
>       n @filenames(_var) @filenames(_seis) @filenames(_peak);
> // Auxillary functions for the mappers
> type StationFile;
> app (StationFile _stat) getsite_file(int _run_id) {
>   getsite _run_id stdout=@filename(_stat);
> (Station _stat) get_site(int _run_id) {
>   StationFile file<"/var/tmp/site_tmp">;
>   /*file = getsite_file(_run_id);*/
>   _stat = readData(file);
> type RuptureFile;
> app (RuptureFile _rup) getrupture_file(int _run_id) {
>   getrupture _run_id stdout=@filename(_rup);
> (Rupture _rup[]) get_ruptures(int _run_id, Station _site) {
>   /*RuptureFile file<single_file_mapper; file=@strcat(_site.name,
> "/rup_tmp")>;*/
>   RuptureFile file<"LGU/rup_tmp">;
>   /*file = getrupture_file(_run_id);*/
>   _rup = readData(file);
> type VariationFile;
> app (VariationFile _var) getvariation_file(Station _site, Rupture _rup,
>     string _loc) {
>   variation_mapper "-e" _site.erf "-v" _site.variation_scenario
>       "-l" _loc "-s" _rup.source "-r" _rup.index stdout=@_var;
> (string _vars[]) get_variations(Station _site, Rupture _rup, string _loc){
>   string fname = @strcat(_rup.source, "_", _rup.index);
>   VariationFile file<single_file_mapper;
>       file=@strcat(_site.name, "/varlist/", _rup.source, "/", fname, ".txt")>;
>   /*file = getvariation_file(_site, _rup, _loc);*/
>   _vars = readData(file);
> type offset {
>   int off;
>   int size;
> type offset_file;
> (offset _off[]) mkoffset(int _size, int _group_size) {
>    offset_file file <single_file_mapper; file=@strcat("LGU/offset-",_size)>;
>    file = mkoffset_file(_size, _group_size);
>    _off = readData(file);
> app (offset_file _off) mkoffset_file(int _size, int _group_size) {
>   mkoffset _size _group_size;
> /* TODO: data management zip jobs */
> /* Main program */
> int run_id = 664;
> int agg_size = 80;
> int loc_size = 20;
> string datadir =
>   "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results";
> Station site = get_site(run_id);
> Sgt sgt_var <ext; exec="getsgtvar.rb", r=run_id, s=site.name,
>   l="gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/SgtFiles">;
> Rupture rups[] = get_ruptures(run_id, site);
> foreach rup in rups {
>   string loc_sub = @strcat(datadir, "/", site.name, "/", rup.source,
> "/", rup.index);
>   Sgt sub <ext; exec="getsub.rb", l=loc_sub, n=site.name, s=rup.source,
>       r=rup.index>;
>   string var_str[] = get_variations( site, rup,
>       "gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations"
>   Variation vars[] <array_mapper; files=var_str>;
>   sub = extract(sgt_var,  site, vars[rup.size-1]);
>   string seis_str[];
>   string peak_str[];
>   foreach var,i in vars {
>     seis_str[i] = @strcat(loc_sub, "/Seismogram_", site.name, "_", rup.source,
>                           "_", rup.index, "_", i, ".grm");
>     peak_str[i] = @strcat(loc_sub, "/PeakVals_", site.name, "_", rup.source,
>                           "_", rup.index, "_", i, ".bsa");
>   Seismogram seis[] <array_mapper; files=seis_str>;
>   PeakValue  peak[] <array_mapper; files=peak_str>;
>   if(rup.size <= loc_size) {
>      * Not worth to transfer the data. Execute on TeraGrid instead.
>      * Also execute on localhost.
>       (seis[i], peak[i]) = seispeak_local(sub, var, site);
>   } else {if(rup.size <= agg_size) {
>     /* Execute on a single resource */
>     (seis, peak) = seispeak_agg(sub, vars, site, rup.size);
>   } else {
>     /*offset offs[] = mkoffset(rup.size, agg_size);*/
>     /*for i in offs {*/
>       /*(seis, peak) = seispeak_agg(sub, vars[i.off:i.off+off.size],*/
>                                   /*off.size);*/
> 2011/3/27 Mihael Hategan <hategan at mcs.anl.gov>:
> > I don't believe you. There is no SgtDim data type in that script.
> > Mihael
> > On Sun, 2011-03-27 at 16:55 -0500, Allan Espinosa wrote:
> >> Here it is.  The get_app() calls are simple wrappers to readData()
> >> type offset {
> >>   int off;
> >>   int size;
> >> type offset_file;
> >> /* Main program */
> >> int run_id = 664;
> >> int agg_size = 80;
> >> int loc_size = 20;
> >> string datadir =
> >> "/", rup.index);
> >>       r=rup.index>;
> >>   string seis_str[];
> >>   string peak_str[];
> >>   } else {
> >>     /*for i in offs {*/
> >>                                   /*off.size);*/
> >> > May I see the script?
> >> > On Fri, 2011-03-25 at 19:42 -0500, Allan Espinosa wrote:
> >> >> this has been occurring for 70 times already.  What i expect is for
> >> >> the app with SgtDim sub to run and close the future.
> >> >> 2011-03-25 19:40:12,217-0500 WARN  HangChecker No events in 10s.
> >> >> Registered futures:
> >> >> Rupture[] rups  Closed, 1 elements, 0 listeners
> >> >> Variation vars - Closed, no listeners
> >> >> SgtDim sub - Open, 1 listeners
> >> >> string site  Closed, no listeners
> >> >> Variation[] vars  Closed, 72 elements, 0 listeners
> >> >> Waiting threads:
> >> >> 0-13
> >> >> 0-13-0-7
> >> >> 0-13-0-8-1-1
