[Swift-devel] Swift error: Application not available
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Mar 17 18:28:42 CDT 2011
Hello,
I am trying Swift running on beagle talking to its PBS resources. However,
it seems I am getting inconsistent error messages.
I have following files(all attached): a swift source, tc(transaction),
sites.xml, cf(config), a binary
First, I try the following commandline:
swift -config cf -tc.file tc -sites.file sites.xml catsnsleep.swift -n=1
And get the following error:
The application "catnap" is not available in your tc.data catalog
Caused by: org.globus.cog.karajan.scheduler.NoSuchResourceException
Final status:  Failed:1
The following errors have occurred:
1. The application "catnap" is not available in your tc.data catalog
However, the application *is* available in tc since the following altered
commandline (intended for local execution) works:
swift -tc.file tc catsnsleep.swift -n=1
Swift svn swift-r4143 (swift modified locally) cog-r3056 (cog modified
locally)
RunID: 20110317-1709-9akduibd
Progress:
Progress:  Checking status:1
Final status:  Finished successfully:1
Finally when I just skip the config and use only the sites.xml as in the
swift -tc.file tc -sites.file sites.xml catsnsleep.swift -n=1
I get the following:
Execution failed:
May be, I am missing something or doing something wrong. However, from an
end user/ beginning user point of view it seems the error messages are not
consistent/informative.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110317/ea69d793/attachment.html>
Ketan's Test Data
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110317/ea69d793/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110317/ea69d793/attachment-0001.obj>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110317/ea69d793/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110317/ea69d793/attachment-0002.obj>
