[Swift-devel] Re: Proposal for coaster service options
Mihael Hategan hategan at mcs.anl.gov
Thu Mar 10 11:59:37 CST 2011
Sounds good. These make sense.
Mihael
On Thu, 2011-03-10 at 08:27 -0600, Michael Wilde wrote:
> Mihael,
> I want to work with Ketan to make the various coater startup scripts that we've developed suitable and documented for end user use.
> As a start, can you consider something like the following enhancement to coaster-service:
> -L  Go into passive mode
> -s  service port
> -S  file to write service port number to
>     (forces dynamic port selection starting with -s port number)
> -w  passive worker connection port
> -W  file to write worker port to
> This would make the startup scripts much simpler and cleaner: we would not have to run a dummy swift script to force the service to go into passive mode, and we would not have to scrape the standard output for the passive port number, and we could control whether we use a fixed port or a dynamically selected port.
> - Mike
