asciidoc: Re: [Swift-devel] A suggested web content strategy for	Swift
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Wed Mar  2 20:17:16 CST 2011
Hello again,
This page:
http://diveintopython3.org/about.html
indicates jquery is used along with some javascript programs for syntax
highlight.
Ketan
On Wed, Mar 2, 2011 at 8:07 PM, Ketan Maheshwari <ketancmaheshwari at gmail.com
> wrote:
> Hello,
> Check out the following:
> I thought they have a beautiful layout and if you see one of the chapters
> the code and its associated description has a nice highlight feature.
> Additionally the text into blue boxes that appears on the side gives it more
> elegance. e.g.
> http://diveintopython3.org/strings.html
> I am looking into how they are generated; meanwhile I thought to push it
> here just in case someone knows already the strategy used to generate these
> pages.
> From the footer links, seems the pages are available in multiple languages.
> This kinda indicates they are autogenerated.
> Regards,
> Ketan
> On Tue, Mar 1, 2011 at 9:34 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> And, in defense of docbook, there is "asciidoc" - like reStructured text
>> but for docbook:
>>  http://www.methods.co.nz/asciidoc/index.html
>> and
>>  http://kaczanowscy.pl/tomek/2010-09/a-perfect-environment-for-docbook
>> The asciidoc user guide, presumably done using asciidoc, has some
>> resemblance to our current User Guide:
>>  http://www.methods.co.nz/asciidoc/userguide.html
>> This might let us make a smoother evolution from our current docbook
>> markup to a kinder gentler markup.
>> Justin, I am with you on deciding this soon. We may need some more
>> experiments to do that.
>> - Mike
>> ----- Original Message -----
>> > Yeah, that looks tedious. But there is also this form which works for
>> > most layouts:
>> > Simple table:
>> > Inputs Output
>> > A B A or B
>> > False False False
>> > True False True
>> > False True True
>> > True True True
>> > I dont think tables will make or break it for us.
>> > I like the simple style of most of the other text constructs.
>> > - Mike
>> > > > > For what it's worth, I think that if folks don't want docbook
>> > > > > (which
>> > > > > I'd
>> > > > > more inclined to drop if there was any other reasonable
>> > > > > equivalent
>> > > > > system that produces good html output),
>> > > > Did you look at the reStructured text and Sphinx alternative I
>> > > > described, which is used by Python and many other projects?
>> > > I believe that expressing tables like this:
>> > > | row 1, col 1 | column 2 | column 3 | column 4 |
>> > > | row 2 | Use the command ``ls | more``. |
>> > > | row 3 | | | |
>> > > ... is silly. You are drawing tables in text. Imagine the amount of
>> > > work
>> > > required to add or remove a column.
>> > > The reason one would use this is if it would be desirable for the
>> > > documentation to look presentable in a plain text source file.
>> > Michael Wilde
>> > Computation Institute, University of Chicago
>> > Mathematics and Computer Science Division
>> > Argonne National Laboratory
>> Michael Wilde
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110302/66db6f9a/attachment.html>
