[Swift-devel] A suggested web content strategy for Swift
Mihael Hategan
hategan at mcs.anl.gov
Tue Mar 1 12:09:10 CST 2011
On Tue, 2011-03-01 at 11:54 -0600, Michael Wilde wrote:
> > For what it's worth, I think that if folks don't want docbook (which
> > I'd
> > more inclined to drop if there was any other reasonable equivalent
> > system that produces good html output),
> Did you look at the reStructured text and Sphinx alternative I described, which is used by Python and many other projects?
I believe that expressing tables like this:
| row 1, col 1 | column 2 | column 3 | column 4 |
| row 2 | Use the command ``ls | more``. |
| row 3 | | | |
... is silly. You are drawing tables in text. Imagine the amount of work
required to add or remove a column.
The reason one would use this is if it would be desirable for the
documentation to look presentable in a plain text source file.
