[Swift-devel] Fwd: [Bug 453] New: Swift accepts bad sites parameters without warning to user
Michael Wilde
wilde at mcs.anl.gov
Wed Jun 29 15:57:06 CDT 2011
Sarah,
The only detailed list I know of is for the coaster provider, in the User Guide. And even that is likely not 100% in sync with the code.
Anything you can do to create such a list as part of this bug fix would be great.
- Mike
----- Original Message -----
hey all, i've added a check for some of the incorrect parameters for local execution provider but need to add for the other providers....this is perhaps a naively optimistic question :) but is there a comprehensive list of which parameters are accepted by which provider? just thought i'd check before continuing to dig around for them.
thanks
~sk
---------- Forwarded message ----------
Date: Fri, Jun 24, 2011 at 10:29 AM
Subject: [Bug 453] New: Swift accepts bad sites parameters without warning to user
To: skenny at uchicago.edu
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=453
Summary: Swift accepts bad sites parameters without warning to
user
Product: Swift
Version: 0.92
Platform: All
OS/Version: All
Status: ASSIGNED
Severity: major
Priority: P1
Component: SwiftScript language
AssignedTo: skenny at uchicago.edu
ReportedBy: wilde at mcs.anl.gov
In the newuser-guide pads-quickstart, we tell the user to use the following
sites file:
<config>
<pool handle="pads-pbs">
<execution jobmanager="local:pbs" provider="local" url="none" />
<filesystem provider="local" url="none" />
<profile key="jobThrottle" namespace="karajan">0</profile>
<profile namespace="globus" key="project">_QUEUE_</profile>
<workdirectory>_WORK_</workdirectory>
</pool>
</config>
which is included from the test/ directory.
This file is half coasters, half plain pbs, and as a result happily runs the
users jobs on localhost - without any indication of problems.
Swift should warn the user (or give a fatal error) if parameters specified in
the sites file dont apply to the selected provider(s).
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are the assignee for the bug.
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110629/3811a62b/attachment.html>
