[Swift-devel] Re: Associative arrays issue
Yadu Nand yadudoc1729 at gmail.com
Tue Jun 21 10:16:50 CDT 2011
> I've come across a very curious situation in which
> array["key"][1]  works while array["key"]["id1"] fails.
I've found that the problem is not from the arrays but from
the foreach construct I was using. Foreach expects an
int for the index, whereas in this case the index being a
string fails. I'm trying to fix this.
Thanks and Regards,
Yadu Nand B
