[Swift-devel] Swift unresponsive while using local provider.
    Jonathan Monette
    jonmon at utexas.edu
    Sat Jun 18 00:18:13 CDT 2011
I would say maybe Mihael mispoke.  I think he meant to say the line 575 of the source is not in the addListener method.  The addListener method is indeed in AbstractDataNode but line 575 is not part of the method.
On Jun 18, 2011, at 12:08 AM, Alberto Chavez wrote:
> I already did the svn updates for cog, and swift, rebuilt swift with ant redist, and ant clean + ant dist,
> the test keeps hanging, but I'm missing probably something:
> $ svn update cog
> At revision 3167.
> $ cd cog/modules/
> $ svn update swift
> At revision 4632.
> I did ant redist, and it was successfully built, but the test is still hanging, now it hung on the 11th iteration. However I'm not quite sure if the svn was properly updated, since I did
> $ jstack -l 11471 | grep addListener
>         at org.griphyn.vdl.mapping.AbstractDataNode.addListener(AbstractDataNode.java:583)
> but Mihael Mentioned that addListener is not AbstractDataNode in the newer version.
> Any thoughts on that?
> Alberto.
> > Subject: RE: [Swift-devel] Swift unresponsive while using local provider.
> > From: hategan at mcs.anl.gov
> > To: alberto_chavez at live.com
> > CC: ketancmaheshwari at gmail.com; swift-devel at ci.uchicago.edu
> > Date: Fri, 17 Jun 2011 21:09:04 -0700
> > On Fri, 2011-06-17 at 22:50 -0500, Alberto Chavez wrote:
> > > Oops, Too late.
> > > Do i need to do ant clean , and ant dist again?
> > You're probably fine in most cases with just "ant dist". But if you want
> > to be sure, do what Jonathan is saying: "ant redist"
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110618/a129919b/attachment.html>
