[Swift-devel] Swift unresponsive while using local provider.
Alberto Chavez
alberto_chavez at live.com
Sat Jun 18 00:08:12 CDT 2011
I already did the svn updates for cog, and swift, rebuilt swift with ant redist, and ant clean + ant dist,the test keeps hanging, but I'm missing probably something:
$ svn update cog At revision 3167.
$ cd cog/modules/$ svn update swift At revision 4632.
I did ant redist, and it was successfully built, but the test is still hanging, now it hung on the 11th iteration. However I'm not quite sure if the svn was properly updated, since I did
$ jstack -l 11471 | grep addListener at org.griphyn.vdl.mapping.AbstractDataNode.addListener(AbstractDataNode.java:583) at org.griphyn.vdl.mapping.AbstractDataNode.addListener(AbstractDataNode.java:583)
but Mihael Mentioned that addListener is not AbstractDataNode in the newer version.Any thoughts on that?
Alberto.
> Subject: RE: [Swift-devel] Swift unresponsive while using local provider.
> From: hategan at mcs.anl.gov
> To: alberto_chavez at live.com
> CC: ketancmaheshwari at gmail.com; swift-devel at ci.uchicago.edu
> Date: Fri, 17 Jun 2011 21:09:04 -0700
> On Fri, 2011-06-17 at 22:50 -0500, Alberto Chavez wrote:
> > Oops, Too late.
> > Do i need to do ant clean , and ant dist again?
> You're probably fine in most cases with just "ant dist". But if you want
> to be sure, do what Jonathan is saying: "ant redist"
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110618/4663338f/attachment.html>
