[Swift-devel] Swift unresponsive while using local provider.
    Jonathan Monette
    jonmon at utexas.edu
    Fri Jun 17 23:02:42 CDT 2011
I am not sure.  The command always use it ant redist.  This will clean and compile the code in one call.  Just to be sure :)
On Jun 17, 2011, at 10:50 PM, Alberto Chavez wrote:
> Oops, Too late.
> Do i need to do ant clean , and ant dist again?
> Date: Fri, 17 Jun 2011 22:50:17 -0500
> Subject: Re: [Swift-devel] Swift unresponsive while using local provider.
> From: ketancmaheshwari at gmail.com
> To: alberto_chavez at live.com
> CC: hategan at mcs.anl.gov; swift-devel at ci.uchicago.edu
> Alberto,
> Just a note that do an "ant clean" before you do "ant dist". A mistake I did last week.
> Ketan
> On Fri, Jun 17, 2011 at 10:48 PM, Alberto Chavez <alberto_chavez at live.com> wrote:
> I forgot to rebuild, sorry.
> > Subject: RE: [Swift-devel] Swift unresponsive while using local provider.
> > From: hategan at mcs.anl.gov
> > CC: davidkelly999 at gmail.com; swift-devel at ci.uchicago.edu
> > Date: Fri, 17 Jun 2011 20:47:29 -0700
> > On Fri, 2011-06-17 at 22:39 -0500, Alberto Chavez wrote:
> > > It hung on the 2nd iteration, attached is the output.
> > I would then say I don't believe you. Line 575 of AbstractDataNode is
> > not in addListener() in the latest svn code.
> > Make sure you have updated the code and re-compiled swift and that you
> > are running the correct version of swift. If in doubt post the log (it
> > contains the swift svn revision).
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/733419a9/attachment.html>
