[Swift-devel] Swift unresponsive while using local provider.
Alberto Chavez
alberto_chavez at live.com
Fri Jun 17 22:50:58 CDT 2011
Oops, Too late. Do i need to do ant clean , and ant dist again?
Date: Fri, 17 Jun 2011 22:50:17 -0500
Subject: Re: [Swift-devel] Swift unresponsive while using local provider.
To: alberto_chavez at live.com
CC: hategan at mcs.anl.gov; swift-devel at ci.uchicago.edu
Alberto,
Just a note that do an "ant clean" before you do "ant dist". A mistake I did last week.
Ketan
On Fri, Jun 17, 2011 at 10:48 PM, Alberto Chavez <alberto_chavez at live.com> wrote:
I forgot to rebuild, sorry.
> Subject: RE: [Swift-devel] Swift unresponsive while using local provider.
> From: hategan at mcs.anl.gov
> CC: davidkelly999 at gmail.com; swift-devel at ci.uchicago.edu
> Date: Fri, 17 Jun 2011 20:47:29 -0700
> On Fri, 2011-06-17 at 22:39 -0500, Alberto Chavez wrote:
> > It hung on the 2nd iteration, attached is the output.
> I would then say I don't believe you. Line 575 of AbstractDataNode is
> not in addListener() in the latest svn code.
> Make sure you have updated the code and re-compiled swift and that you
> are running the correct version of swift. If in doubt post the log (it
> contains the swift svn revision).
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/785843f6/attachment.html>
