[Swift-devel] Swift unresponsive while using local provider.
Alberto Chavez alberto_chavez at live.com
Fri Jun 17 21:48:04 CDT 2011
> > I already did that in the revision I have, and the tests passed every
> > iteration; I am going to update my working copies to the latest svn
> > code, and I'll run it again.
> If you want to help, please hold on a second.
> Let me give you some background. This is a bug that doesn't happen on
> every run. I may stand on one foot and chant things to the god of rain,
> then run the test and have it run ok. Therefore I may conclude that my
> chanting solved the problem. But you can see how the argument is bogus.
> Clearly the god of rain has no bearing on computer code.
> So there are many things you could do after which running a script
> works, but the important test here is to run the same script repeatedly
> and see the frequency with which the problem happens.
> So please run the same script 100 times without updating the code from
> svn and report back the results.
Got it.
> > By the way, I put sites.template.xml back, and ran the command jstack
> > This is the output:
> > $ jstack -l 2791
> And how did you come upon the number 2791?
that's the process ID of swift.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/09314e3b/attachment.html>
