[Swift-devel] Swift unresponsive while using local provider.
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 17 19:54:25 CDT 2011
On Fri, 2011-06-17 at 19:29 -0500, Alberto Chavez wrote:
> I already did that in the revision I have, and the tests passed every
> iteration; I am going to update my working copies to the latest svn
> code, and I'll run it again.
If you want to help, please hold on a second.
Let me give you some background. This is a bug that doesn't happen on
every run. I may stand on one foot and chant things to the god of rain,
then run the test and have it run ok. Therefore I may conclude that my
chanting solved the problem. But you can see how the argument is bogus.
Clearly the god of rain has no bearing on computer code.
So there are many things you could do after which running a script
works, but the important test here is to run the same script repeatedly
and see the frequency with which the problem happens.
So please run the same script 100 times without updating the code from
svn and report back the results.
> By the way, I put sites.template.xml back, and ran the command jstack
> This is the output:
> $ jstack -l 2791
And how did you come upon the number 2791?
