[Swift-devel] Swift unresponsive while using local provider.
Mihael Hategan
hategan at mcs.anl.gov
Fri Jun 17 19:55:06 CDT 2011
On Fri, 2011-06-17 at 17:50 -0700, Mihael Hategan wrote:
> On Fri, 2011-06-17 at 19:47 -0500, Jonathan Monette wrote:
> > I meant what was the swift command line that is executed but if it is
> > run within the test suite I guess you don't know that upfront.
> > The reason I am asking is I wanted to know what sites file the test
> > suite reverted to when you moved the other on out. Since you set the
> > workdirectory to /tmp I thought maybe /tmp was being filled up which
> > was causing the timeouts and hangs since there was no more room in the
> > workdirectory.
> $SWIFT_HOME/etc/sites.xml which has local/local as providers.
> But now. The deadlock has nothing to do with disk space. The stack trace
"But no" ^^
> shows what the problem is. So I would suggest ignoring the sites file
> issue, since I believe it completely uncorrelated with the deadlock we
> are talking about.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
