[Swift-devel] Swift unresponsive while using local provider.
Mihael Hategan hategan at mcs.anl.gov
Fri Jun 17 19:50:46 CDT 2011
On Fri, 2011-06-17 at 19:47 -0500, Jonathan Monette wrote:
> I meant what was the swift command line that is executed but if it is
> run within the test suite I guess you don't know that upfront.
> The reason I am asking is I wanted to know what sites file the test
> suite reverted to when you moved the other on out.  Since you set the
> workdirectory to /tmp I thought maybe /tmp was being filled up which
> was causing the timeouts and hangs since there was no more room in the
> workdirectory.
$SWIFT_HOME/etc/sites.xml which has local/local as providers.
But now. The deadlock has nothing to do with disk space. The stack trace
shows what the problem is. So I would suggest ignoring the sites file
issue, since I believe it completely uncorrelated with the deadlock we
are talking about.
