[Swift-devel] Re: [Bug 183] Print better error message when app executable is not found
Sarah Kenny skenny at uchicago.edu
Wed Jun 15 11:34:39 CDT 2011
hmm...so in my tc.data file i have the entry:
localhost   echo   /bad/path/echo INSTALLED INTEL64::LINUX null
then running 'hello world' i still get what seems like a reasonable error:
 The executable /bad/path/echo does not exist
so apparently it's not just the path/executable name that's giving you guys
an error.
On Wed, Jun 15, 2011 at 9:03 AM, Jonathan Monette <jonmon at utexas.edu> wrote:
> From the error you got and the error I got I am thinking that the path to
> an executable and the executable name in the tc file are different things.
>  /bin/echoo says that the executable echoo does not exist in /bin.
>  Something like /home/jonmon/hereiam/echo, the directory hereiam doesn't
> exist so it returns a different error.  Maybe the path in the tc.data file
> was supposed to have hereami not hereiam.  That is what I meant by "not
> just".  The path to an executable doesn't exist "not just" the executable is
> missing.
> On Jun 15, 2011, at 10:58 AM, sarah kenny wrote:
> On Jun 15, 2011, at 7:24 AM, Jonathan Monette <jonmon at utexas.edu> wrote:
> I don't think that is the problem.  What if you have the wrong path to the
> executable not just ?  This is the error I got.
> sorry I don't understand what is meant by "not just ?" I have the wrong
> path to the executable in my tc.data...
> RunID: 20110615-0909-if0uyvm1
> Progress:
> Progress: Failed but can retry:1
> Job failed with an exit code of 254
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
> Execution failed:
> I used the stable release to reproduce this and this is the error that I
> got using the trunk.
> Progress:  time: Wed, 15 Jun 2011 09:18:42 -0500  Initializing:1
> Progress:  time: Wed, 15 Jun 2011 09:18:43 -0500 Failed but can retry:1
> null
> org.globus.cog.abstraction.impl.file.FileNotFoundException: File not found:
> /home/jonmon/test/work/localhost/tc_test-20110615-0918-46b6tgld/jobs/8/hello-80d4plbk/stderr.txt
> at
> org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
> at
> org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:268)
> at
> org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:158)
> at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:314)
> at
> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
> at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:487)
> at java.lang.Thread.run(Thread.java:662)
> /home/jonmon/test/work/localhost/tc_test-20110615-0918-46b6tgld/jobs/8/hello-80d4plbk/?:string
> = out.txt - Closed
> at
> at
> at
> at
> at
> at
> Execution failed:
> The files used are located in ~jonmon/test on the ci machines.
> On Jun 15, 2011, at 1:05 AM, Sarah Kenny wrote:
> hey david, i've been trying to replicate this bug, but when i deliberately
> point to an executable that doesn't exist i get what seems to be an
> appropriate error:
> The executable /bin/echoo does not exist
> i got this on a couple of sites...can you give a little more info on what
> was happening with your workflow? could be i'm misunderstanding the bug.
> ~sk
> On Fri, Jun 10, 2011 at 9:31 PM, < <bugzilla-daemon at mcs.anl.gov>
> bugzilla-daemon at mcs.anl.gov> wrote:
>> <https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=183>
>> David Kelly < <davidkelly999 at gmail.com>davidkelly999 at gmail.com> changed:
>>           What    |Removed                     |Added
>>                 CC|                            |<davidkelly999 at gmail.com>
>>          Component|SwiftScript language        |error messages
>>         AssignedTo| <benc at hawaga.org.uk>benc at hawaga.org.uk          |<skenny at uchicago.edu>
>> --- Comment #1 from David Kelly < <davidkelly999 at gmail.com>
>> davidkelly999 at gmail.com>  2011-06-10 23:32:22 ---
>> This one gets my vote.. I just wasted a bunch of time trying to figure out
>> what
>> this error meant and why I was getting it.
>> Configure bugmail:
>> <https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email>
>> ------- You are receiving this mail because: -------
>> You are the assignee for the bug.
> Swift-devel mailing list
> <Swift-devel at ci.uchicago.edu>Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110615/942b1f40/attachment.html>
