[Swift-devel] Re: [Bug 183] Print better error message when app executable is not found
Jonathan Monette
jonmon at utexas.edu
Wed Jun 15 11:03:58 CDT 2011
From the error you got and the error I got I am thinking that the path to an executable and the executable name in the tc file are different things. /bin/echoo says that the executable echoo does not exist in /bin. Something like /home/jonmon/hereiam/echo, the directory hereiam doesn't exist so it returns a different error. Maybe the path in the tc.data file was supposed to have hereami not hereiam. That is what I meant by "not just". The path to an executable doesn't exist "not just" the executable is missing.
On Jun 15, 2011, at 10:58 AM, sarah kenny wrote:
> On Jun 15, 2011, at 7:24 AM, Jonathan Monette <jonmon at utexas.edu> wrote:
>> I don't think that is the problem. What if you have the wrong path to the executable not just ? This is the error I got.
> sorry I don't understand what is meant by "not just ?" I have the wrong path to the executable in my tc.data...
>> RunID: 20110615-0909-if0uyvm1
>> Progress:
>> Progress: Failed but can retry:1
>> Job failed with an exit code of 254
>> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 254
>> Execution failed:
>> I used the stable release to reproduce this and this is the error that I got using the trunk.
>> Progress: time: Wed, 15 Jun 2011 09:18:42 -0500 Initializing:1
>> Progress: time: Wed, 15 Jun 2011 09:18:43 -0500 Failed but can retry:1
>> null
>> org.globus.cog.abstraction.impl.file.FileNotFoundException: File not found: /home/jonmon/test/work/localhost/tc_test-20110615-0918-46b6tgld/jobs/8/hello-80d4plbk/stderr.txt
>> at org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
>> at org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:268)
>> at org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:158)
>> at org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:314)
>> at org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
>> at org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:487)
>> at java.lang.Thread.run(Thread.java:662)
>> org.globus.cog.abstraction.impl.file.FileNotFoundException: File not found: /home/jonmon/test/work/localhost/tc_test-20110615-0918-46b6tgld/jobs/8/hello-80d4plbk/?:string = out.txt - Closed
>> Execution failed:
>> The files used are located in ~jonmon/test on the ci machines.
>> On Jun 15, 2011, at 1:05 AM, Sarah Kenny wrote:
>>> hey david, i've been trying to replicate this bug, but when i deliberately point to an executable that doesn't exist i get what seems to be an appropriate error:
>>> The executable /bin/echoo does not exist
>>> i got this on a couple of sites...can you give a little more info on what was happening with your workflow? could be i'm misunderstanding the bug.
>>> ~sk
>>> On Fri, Jun 10, 2011 at 9:31 PM, <bugzilla-daemon at mcs.anl.gov> wrote:
>>> https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=183
>>> David Kelly <davidkelly999 at gmail.com> changed:
>>> What |Removed |Added
>>> CC| |davidkelly999 at gmail.com
>>> Component|SwiftScript language |error messages
>>> AssignedTo|benc at hawaga.org.uk |skenny at uchicago.edu
>>> --- Comment #1 from David Kelly <davidkelly999 at gmail.com> 2011-06-10 23:32:22 ---
>>> This one gets my vote.. I just wasted a bunch of time trying to figure out what
>>> this error meant and why I was getting it.
>>> Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
>>> ------- You are receiving this mail because: -------
>>> You are the assignee for the bug.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110615/cd69c102/attachment.html>
