[Swift-devel] Walltime in PBS submit files
David Kelly
davidkelly999 at gmail.com
Fri Jun 3 10:11:27 CDT 2011
That did the trick. I bumped up the maxtime to 300 and it ran immediately.
Thanks for the info!
David
On Fri, Jun 3, 2011 at 9:54 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> David,
> Im not sure what coasters is thinking here. But first thing I would try is
> to set the maxtime value in sites.xml (which is in integer seconds) to
> something like 300 to make coasters realize that it can fit at least 10
> 30-second app calls into the 300 second coaster block.
> With maxtime < maxwalltime coasters may be erroneously starting a block but
> finding that its unable to fit *any* app calls into it.
> There are also settings you can apply (overallocation etc) to make maxtime
> more of an "exact time" setting. For example, if you do this:
> <profile namespace="globus" key="maxTime">1800</profile>
> <profile namespace="globus" key="lowOverAllocation">100</profile>
> <profile namespace="globus" key="highOverAllocation">100</profile>
> ...then each coaster block started should have a maxwalltime of 1800 secs.
> But your app maxwalltime needs to fit into this block time.
> - Mike
> Hello,
> I am trying to use the shared queue on Fusion. This queue requires a
> walltime of less than one hour. I have all of the applications in my tc.data
> file set up with a walltime of 30 seconds. In my sites.xml, I specify a
> maxtime of 10. However, when Swift generates the PBS submit file, it
> specifies a walltime of 00:00:00 which prevents it from running.
> How can I make Swift set the walltime in these PBS submit scripts?
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110603/8a8f4747/attachment.html>
