[Swift-devel] Walltime in PBS submit files
Michael Wilde wilde at mcs.anl.gov
Fri Jun 3 09:54:52 CDT 2011
David,
Im not sure what coasters is thinking here. But first thing I would try is to set the maxtime value in sites.xml (which is in integer seconds) to something like 300 to make coasters realize that it can fit at least 10 30-second app calls into the 300 second coaster block.
With maxtime < maxwalltime coasters may be erroneously starting a block but finding that its unable to fit *any* app calls into it.
There are also settings you can apply (overallocation etc) to make maxtime more of an "exact time" setting. For example, if you do this:
<profile namespace="globus" key="maxTime">1800</profile>
<profile namespace="globus" key="lowOverAllocation">100</profile>
<profile namespace="globus" key="highOverAllocation">100</profile>
...then each coaster block started should have a maxwalltime of 1800 secs.
But your app maxwalltime needs to fit into this block time.
- Mike
----- Original Message -----
Hello,
I am trying to use the shared queue on Fusion. This queue requires a walltime of less than one hour. I have all of the applications in my tc.data file set up with a walltime of 30 seconds. In my sites.xml, I specify a maxtime of 10. However, when Swift generates the PBS submit file, it specifies a walltime of 00:00:00 which prevents it from running.
How can I make Swift set the walltime in these PBS submit scripts?
David
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110603/16e73341/attachment.html>
