[Swift-devel] Updates - Tests
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jul 19 13:56:05 CDT 2011
On Tue, 2011-07-19 at 03:23 +0530, Yadu Nand wrote:
> Hi,
> > Also the <variable> thing. I have a suspicion that you can use a
> > function on the template to extract the contents of that tag rather than
> > rendering it to a string and then parsing it again in custom code.
> > So let me know if you want to fix those issues. They will have to be
> > fixed sooner or later by somebody.
> I've moved the code to a separate function so that the foreachstat
> function in Karajan.java looks neater now. As you suggest there
> might be some way to get it from the string template, but my efforts
> didn't get me there.
> There were a couple of multidimensional array based tests that were
> failing. Multidimensional arrays with assignments of the form :
> string array[ ][ ];
> array = [ [ "left" , "right" ] [ "up", "down" ] ];
> trace ( array[0][0], array[0][1], array[1][0], array[1][1] );
> I tried to fix this, but later I tried running swift clean, with none of my
> code in it, and it still failed. Should I try to fix this ?
> The same for mappers, but here as Justin pointed out, the tests are
> not working right in the early-revision I'm working from.
Right. It may be that other things are broken in the version of swift
you're working against. If you think the code is ok, send me a patch and
I'll merge it to my local checkout and see if I can fix the problems.
