[Swift-devel] Updates - Tests
    Yadu Nand
    yadudoc1729 at gmail.com
    Thu Jul 14 14:42:12 CDT 2011
> So the rest of the trunk code seems to pass most (if not all) of the
> local tests. Perhaps it's time to integrate your changes into trunk and
> go from there. Let me know when you want that to happen, and I'll merge
> your patch locally, tidy it up and commit.
Some of the tests appear to fail, but when I run them independently they
work. I'm not sure what is going on there.
> If there are things in your code that you feel are hackish (i.e. quick
> solutions that seem shady for production), let's discuss/fix them before
> we do the above.
Yes!  In org/griphyn/vdl/engine/Karajan.java, the foreachstat function is
mostly hacks. I'm putting in a code paste :  http://ideone.com/yWbwU
Thanks and Regards,
Yadu Nand B
