[Swift-devel] Updates - Tests
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul 14 14:19:44 CDT 2011
So the rest of the trunk code seems to pass most (if not all) of the
local tests. Perhaps it's time to integrate your changes into trunk and
go from there. Let me know when you want that to happen, and I'll merge
your patch locally, tidy it up and commit.
If there are things in your code that you feel are hackish (i.e. quick
solutions that seem shady for production), let's discuss/fix them before
we do the above.
On Fri, 2011-07-15 at 00:41 +0530, Yadu Nand wrote:
> Hi,
> I've been fixing failed tests from the test suite after adding changes
> to the associative arrays. The support for types as subscripts are
> not ready yet, and I will work on those as soon as tests are okayed.
> I've run tests and fixed most of the issues I think comes from the
> code I've modified. There are some tests which are failing because
> of no-permission and file/directory not found errors. I'm not sure
> what I should do here. So can can someone check ? I'm working
> on an older revision (4697 if I remember correctly).
> I'm attaching the logs from the test as well as a patch.
