[Swift-devel] Updates - Tests
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jul 14 14:18:08 CDT 2011
Yadu, Alberto, Justin, Mihael - can you coordinate on this via the list?
- Mike
----- Original Message -----
> Hi,
> I've been fixing failed tests from the test suite after adding changes
> to the associative arrays. The support for types as subscripts are
> not ready yet, and I will work on those as soon as tests are okayed.
> I've run tests and fixed most of the issues I think comes from the
> code I've modified. There are some tests which are failing because
> of no-permission and file/directory not found errors. I'm not sure
> what I should do here. So can can someone check ? I'm working
> on an older revision (4697 if I remember correctly).
> I'm attaching the logs from the test as well as a patch.
> Thanks and Regards,
> Yadu Nand B
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
