[Swift-devel] Updates - Tests
    Yadu Nand
    yadudoc1729 at gmail.com
    Thu Jul 14 14:11:55 CDT 2011
I've been fixing failed tests from the test suite after adding changes
to the associative arrays. The support for types as subscripts are
not ready yet, and I will work on those as soon as tests are okayed.
I've run tests and fixed most of the issues I think comes from the
code I've modified. There are some tests which are failing because
of no-permission and file/directory not found errors. I'm not sure
what I should do here. So can can someone check ? I'm working
on an older revision (4697 if I remember correctly).
I'm attaching the logs from the test as well as a patch.
Thanks and Regards,
Yadu Nand B
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110715/a57f23fa/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110715/a57f23fa/attachment-0001.bin>
