[Swift-devel] Fwd: trunk FileNotFoundException
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Jul 14 14:08:32 CDT 2011
Hello,
It seems that the Swift on my trunk was a stale version. I updated and
rebuilt after which the NPE has gone.
Ketan
On Tue, Jul 12, 2011 at 8:43 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> The NPE seems legit, and in quite the right spot considering the recent
> commits. But I was trying to figure out the thing with the workdir
> creation.
> In any event, does any of you have a simple test case for the NPE?
> On Tue, 2011-07-12 at 21:29 -0400, Glen Hocky wrote:
> > By the way, I also see this error, w/ pbs+coasters and on osg w/
> > condor, no provider staging
> > On Tue, Jul 12, 2011 at 9:26 PM, Ketan Maheshwari
> > <ketancmaheshwari at gmail.com> wrote:
> >         No, provider staging is not on.
> >         I am using local execution provider:
> >         <pool handle="localhost">
> >             <filesystem provider="local" />
> >             <execution provider="local" />
> >             <workdirectory>/var/tmp/swift.workdir</workdirectory>
> >             <profile namespace="karajan"
> >         key="jobThrottle">0.20</profile>
> >         </pool>
> >         On Tue, Jul 12, 2011 at 8:15 PM, Mihael Hategan
> >                 Is provider staging on?
> >                 On Tue, 2011-07-12 at 14:16 -0500, Ketan Maheshwari
> >                 wrote:
> >                 > Mihael,
> >                 > I tried to further investigate the issue and from
> >                 the logs it seems
> >                 > that Swift is trying to execute the mkoffset app
> >                 before creating a
> >                 > jobs/ directory in workdir. Could it be that this is
> >                 an ordering
> >                 > issue. For instance, I see the following line:
> >                 > 2011-07-12 13:50:49,559-0500 DEBUG vdl:execute2
> >                 JOB_START
> >                 > jobid=mkoffset-mex8fvck tr=mkoffset
> >                 arguments=[200.0, 60.0]
> tmpdir=postproc-20110712-1343-eczky6ob/jobs/m/mkoffset-mex8fvck
> >                 > host=localhost
> >                 > but do not see a createdir corresponding to above.
> >                 > I have ran this workflow successfully with 0.92.1
> >                 so, I am pretty sure
> >                 > that it works correctly as far as order of execution
> >                 is concerned.
> >                 > Thanks for any more insights into this.
> >                 > Regards,
> >                 > Ketan
> >                 > ---------- Forwarded message ----------
> >                 > From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
> >                 > Date: Mon, Jul 11, 2011 at 10:31 PM
> >                 > Subject: trunk FileNotFoundException
> >                 > To: swift-user at ci.uchicago.edu
> >                 > Hello,
> >                 > Using Swift trunk, I am running the SCEC workflow
> >                 from Communicado
> >                 > using ranger, localhost and OSG resources.
> >                 > One particular app 'mkoffset' which is destined to
> >                 run on localhost is
> >                 > faulting with FileNotFoundException.
> >                 > The log does give information on its mapping and
> >                 when it gets
> >                 > 'cleared'.
> >                 > The config, tc, sites and log files for the run
> >                 could be found here:
> >                 > http://www.mcs.anl.gov/~ketan/files/bundle.tgz (log
> >                 is 90M, upload
> >                 > size exceeded!)
> >                 > The error stack that I am getting on stdout is:
> >                 > Progress:  time: Mon, 11 Jul 2011 22:16:38 -0500
> >                  Selecting site:390
> >                 > Stage in:16  Active:9  Checking status:1  Finished
> >                 successfully:36
> >                 > Failed but can retry:3
> org.globus.cog.abstraction.impl.file.FileNotFoundException: File not
> >                 found:
> /var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/stderr.txt
> >                 >     at
> org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
> >                 >     at
> org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:268)
> >                 >     at
> org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:158)
> >                 >     at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:314)
> >                 >     at
> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
> >                 >     at
> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:487)
> >                 >     at java.lang.Thread.run(Thread.java:619)
> >                 found:
> /var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/LGU/offset-128
> >                 >     at
> >                 >     at
> >                 >     at
> >                 >     at
> >                 >     at
> >                 >     at
> >                 > Progress:  time: Mon, 11 Jul 2011 22:16:39 -0500
> >                  Selecting site:389
> >                 successfully:38
> >                 > Failed but can retry:4
> >                 > Execution failed:
> >                 >     java.lang.NullPointerException
> >                 >     at
> org.griphyn.vdl.mapping.AbstractDataNode.getValue(AbstractDataNode.java:333)
> >                 >     at
> org.griphyn.vdl.karajan.lib.SetFieldValue.log(SetFieldValue.java:71)
> >                 >     at
> org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:38)
> >                 >     at
> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:62)
> >                 >     at
> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
> >                 >     at
> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
> >                 >     at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
> >                 >     at
> org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
> >                 >     at
> >                 >     at
> >                 >     at
> >                 >     at
> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:66)
> >                 >     at
> >                 >     at
> >                 >     at
> >                 > Any clues?
> >                 > Thanks,
> >                 > Ketan
> >                 > Ketan
> >         Ketan
> >         _______________________________________________
> >         Swift-devel mailing list
> >         Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110714/b8ad0534/attachment.html>
