[Swift-devel] Fwd: trunk FileNotFoundException
Mihael Hategan hategan at mcs.anl.gov
Tue Jul 12 20:43:38 CDT 2011
The NPE seems legit, and in quite the right spot considering the recent
commits. But I was trying to figure out the thing with the workdir
creation.
In any event, does any of you have a simple test case for the NPE?
On Tue, 2011-07-12 at 21:29 -0400, Glen Hocky wrote:
> By the way, I also see this error, w/ pbs+coasters and on osg w/
> condor, no provider staging
> On Tue, Jul 12, 2011 at 9:26 PM, Ketan Maheshwari
> <ketancmaheshwari at gmail.com> wrote:
>         No, provider staging is not on.
>         I am using local execution provider:
>         <pool handle="localhost">
>             <filesystem provider="local" />
>             <execution provider="local" />
>             <workdirectory>/var/tmp/swift.workdir</workdirectory>
>             <profile namespace="karajan"
>         key="jobThrottle">0.20</profile>
>         </pool>
>         On Tue, Jul 12, 2011 at 8:15 PM, Mihael Hategan
>         <hategan at mcs.anl.gov> wrote:
>                 Is provider staging on?
>                 On Tue, 2011-07-12 at 14:16 -0500, Ketan Maheshwari
>                 wrote:
>                 > Mihael,
>                 > I tried to further investigate the issue and from
>                 the logs it seems
>                 > that Swift is trying to execute the mkoffset app
>                 before creating a
>                 > jobs/ directory in workdir. Could it be that this is
>                 an ordering
>                 > issue. For instance, I see the following line:
>                 > 2011-07-12 13:50:49,559-0500 DEBUG vdl:execute2
>                 JOB_START
>                 > jobid=mkoffset-mex8fvck tr=mkoffset
>                 arguments=[200.0, 60.0]
>                 tmpdir=postproc-20110712-1343-eczky6ob/jobs/m/mkoffset-mex8fvck
>                 > host=localhost
>                 > but do not see a createdir corresponding to above.
>                 > I have ran this workflow successfully with 0.92.1
>                 so, I am pretty sure
>                 > that it works correctly as far as order of execution
>                 is concerned.
>                 > Thanks for any more insights into this.
>                 > Regards,
>                 > Ketan
>                 > ---------- Forwarded message ----------
>                 > From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
>                 > Date: Mon, Jul 11, 2011 at 10:31 PM
>                 > Subject: trunk FileNotFoundException
>                 > To: swift-user at ci.uchicago.edu
>                 > Hello,
>                 > Using Swift trunk, I am running the SCEC workflow
>                 from Communicado
>                 > using ranger, localhost and OSG resources.
>                 > One particular app 'mkoffset' which is destined to
>                 run on localhost is
>                 > faulting with FileNotFoundException.
>                 > The log does give information on its mapping and
>                 when it gets
>                 > 'cleared'.
>                 > The config, tc, sites and log files for the run
>                 could be found here:
>                 > http://www.mcs.anl.gov/~ketan/files/bundle.tgz (log
>                 is 90M, upload
>                 > size exceeded!)
>                 > The error stack that I am getting on stdout is:
>                 > Progress:  time: Mon, 11 Jul 2011 22:16:38 -0500
>                  Selecting site:390
>                 > Stage in:16  Active:9  Checking status:1  Finished
>                 successfully:36
>                 > Failed but can retry:3
>                 org.globus.cog.abstraction.impl.file.FileNotFoundException: File not
>                 found: /var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/stderr.txt
>                 >     at
>                 org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
>                 >     at
>                 org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:268)
>                 >     at
>                 org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:158)
>                 >     at
>                 org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:314)
>                 >     at
>                 org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
>                 >     at
>                 org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:487)
>                 >     at java.lang.Thread.run(Thread.java:619)
>                 found: /var/tmp/postproc-20110711-2209-bx2qm0nb/jobs/e/mkoffset-ea7xcuck/LGU/offset-128
>                 >     at
>                 >     at
>                 >     at
>                 >     at
>                 >     at
>                 >     at
>                 > Progress:  time: Mon, 11 Jul 2011 22:16:39 -0500
>                  Selecting site:389
>                 successfully:38
>                 > Failed but can retry:4
>                 > Execution failed:
>                 >     java.lang.NullPointerException
>                 >     at
>                 org.griphyn.vdl.mapping.AbstractDataNode.getValue(AbstractDataNode.java:333)
>                 >     at
>                 org.griphyn.vdl.karajan.lib.SetFieldValue.log(SetFieldValue.java:71)
>                 >     at
>                 org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:38)
>                 >     at
>                 org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:62)
>                 >     at
>                 org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
>                 >     at
>                 org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
>                 >     at
>                 org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>                 >     at
>                 org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
>                 >     at
>                 >     at
>                 >     at
>                 >     at
>                 org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:66)
>                 >     at
>                 >     at
>                 >     at
>                 > Any clues?
>                 > Thanks,
>                 > Ketan
>                 > Ketan
>         Ketan
>         _______________________________________________
>         Swift-devel mailing list
>         Swift-devel at ci.uchicago.edu
>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
