[Swift-devel] OSG hang
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul 14 14:07:06 CDT 2011
On Thu, 2011-07-14 at 14:02 -0500, Jonathan Monette wrote:
> So it does seem like the job get run on the head node.  When the job
> is finished on the head node(I checked several times with
> globus-job-run) Swift continues to execute(well it just prints the
> Submitted: 1 line over and over again).
> So the next step is to set those environment variables Mike mentioned and try again?
Yes. Swift won't work properly if those are not set properly. On most
system it guesses them, but not on weird systems.
Setting GLOBUS_HOSTNAME is probably enough though.
