[Swift-devel] OSG hang
    Jonathan Monette
    jonmon at utexas.edu
    Thu Jul 14 13:27:33 CDT 2011
How do I check the distinction?  The output file is not created, the log stops after the GridExec INFO message, and the Swift stdout just says "Progress:  Submitted:1" several times.
On Jul 14, 2011, at 1:24 PM, Mihael Hategan wrote:
> On Thu, 2011-07-14 at 13:14 -0500, Jonathan Monette wrote:
>> Hello,
>>   I am trying to submit jobs from an Amazon VM to an OSG site.  I
>> have tried Engage VO sites with a proxy created by both
>> grid-proxy-init and voms-proxy-init.  When running swift it says it
>> submitted the job but it looks like nothing is executing.
> Is nothing really executing or is it swift not saying anything was done?
> The distinction is important because the latter may mean that the
> service isn't telling swift that stuff was done (this is what I was
> alluding to yesterday when I said that if GLOBUS_HOSTNAME isn't set
> properly, lots of things will break).
>>  This happens when using fork, condor, and pbs. I can successfully
>> execute the script from communicado to OSG using fork with barely any
>> wait time.
>> The files are located in ~jonmon/OSG.0000 on the ci machines.
>> I have filed a bug in bugzilla.
>> Bug 471 - OSG hangs from VM
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
