[Swift-devel] readData2
Justin M Wozniak
wozniak at mcs.anl.gov
Fri Jul 1 21:04:03 CDT 2011
fopen(3) is smart enough to know that "r" means read. Certainly Swift is
smarter than fopen.
However, I think there is a lot of value in allowing users to read
unformatted, "one value per line" data and I don't think we should force
users to convert possibly large text files into Swift format. So, I think
there is value in keeping the two functionalities separate.
If we're going to mandate a file format, we should try to be compatible
with JSON or something. But I don't think we should mandate a file
format.
Justin
On Fri, 1 Jul 2011, Tim Armstrong wrote:
> You could go full unix shell style and call it "rd"
> On Fri, Jul 1, 2011 at 6:09 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> On Fri, 2011-07-01 at 18:04 -0700, Sarah Kenny wrote:
>>> my 2 cents...readStruct...slightly more succinct :)
>> 2 more cents: read. Can't get much better than that.
>>> On Fri, Jul 1, 2011 at 4:22 PM, Jonathan S Monette <jonmon at utexas.edu>
>>> wrote:
>>> I am all for dropping readData. writeData would have to be
>>> modified to output data for "readData2".
>>> Do you have a better name? I thought maybe readMapping or
>>> readExplicitMapping but Justin said the mapping term maybe
>>> should not be used in this case.
>>> On Jul 1, 2011 6:12 PM, "Mihael Hategan" <hategan at mcs.anl.gov>
>>> wrote:
>>> > On Thu, 2011-06-30 at 13:40 -0500, Jonathan Monette wrote:
>>> >> Hello,
>>> >> I am going to rename readData2 to something more
>>> meaningful. I am
>>> >> thinking maybe readStructured? I will keep readData2 as an
>>> alias to
>>> >> the renamed function as too not break anyones current code
>>> but the
>>> >> userguide will reflect the renamed function. Any
>>> suggestions on the
>>> >> name or is readStructured good?
>>> > I think we should drop readData and slowly replace it with
>>> readData2.
>>> > readStructured doesn't seem to be more illuminating to me.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Sarah Kenny
>>> Programmer
>>> University of Chicago, Computation Institute
>>> University of California Irvine, Dept. of Neurology
>>> 773-818-8300
Justin M Wozniak
