[Swift-devel] readData2
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Fri Jul  1 20:12:55 CDT 2011
You could go full unix shell style and call it "rd"
On Fri, Jul 1, 2011 at 6:09 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2011-07-01 at 18:04 -0700, Sarah Kenny wrote:
> > my 2 cents...readStruct...slightly more succinct :)
> 2 more cents: read. Can't get much better than that.
> > On Fri, Jul 1, 2011 at 4:22 PM, Jonathan S Monette <jonmon at utexas.edu>
> > wrote:
> >         I am all for dropping readData. writeData would have to be
> >         modified to output data for "readData2".
> >         Do you have a better name? I thought maybe readMapping or
> >         readExplicitMapping but Justin said the mapping term maybe
> >         should not be used in this case.
> >         On Jul 1, 2011 6:12 PM, "Mihael Hategan" <hategan at mcs.anl.gov>
> >         wrote:
> >         > On Thu, 2011-06-30 at 13:40 -0500, Jonathan Monette wrote:
> >         >> Hello,
> >         >> I am going to rename readData2 to something more
> >         meaningful. I am
> >         >> thinking maybe readStructured? I will keep readData2 as an
> >         alias to
> >         >> the renamed function as too not break anyones current code
> >         but the
> >         >> userguide will reflect the renamed function. Any
> >         suggestions on the
> >         >> name or is readStructured good?
> >         > I think we should drop readData and slowly replace it with
> >         readData2.
> >         > readStructured doesn't seem to be more illuminating to me.
> >         _______________________________________________
> >         Swift-devel mailing list
> >         Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Sarah Kenny
> > Programmer
> > University of Chicago, Computation Institute
> > University of California Irvine, Dept. of Neurology
> > 773-818-8300
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110701/0eb1da74/attachment.html>
