[Swift-devel] readData2
    Jonathan S Monette
    jonmon at utexas.edu
    Fri Jul  1 18:22:23 CDT 2011
I am all for dropping readData. writeData would have to be modified to
output data for "readData2".
Do you have a better name? I thought maybe readMapping or
readExplicitMapping but Justin said the mapping term maybe should not be
used in this case.
On Jul 1, 2011 6:12 PM, "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> On Thu, 2011-06-30 at 13:40 -0500, Jonathan Monette wrote:
>> Hello,
>> I am going to rename readData2 to something more meaningful. I am
>> thinking maybe readStructured? I will keep readData2 as an alias to
>> the renamed function as too not break anyones current code but the
>> userguide will reflect the renamed function. Any suggestions on the
>> name or is readStructured good?
> I think we should drop readData and slowly replace it with readData2.
> readStructured doesn't seem to be more illuminating to me.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110701/34386597/attachment.html>
