[Swift-devel] Please verify 0.92 checkout & build instructions
Sarah Kenny skenny at uchicago.edu
Sun Jan 16 22:15:44 CST 2011
On Thu, Jan 13, 2011 at 10:43 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> OK, that *seems* to work. The argument string is now:
> arguments = /osg/data/engage/tmp/
> ce02.cmsaf.mit.edu/catsn-20110113-1240-vn86uhoc/shared/_swiftwrapcat-jaxfbf4k -jobdir j -scratch \"\" -e /bin/cat -out outdir/f.0001.out -err
> stderr.txt -i -d outdir -if data.txt -of outdir/f.0001.out -k \"\" -cdmfile
> \"\" -status file -a data.txt
> with \"\" for empty args.
> Im going to commit this and test, then get a build of trunk to Marc.
> Sarah, how/when do you want this and other fixes committed to the 0.92
> branch?
> Do you want to do these mods?
i thought the plan was that anything fixes for .92 go into .92, and then we
merge back with trunk after the release (?) however, i'm not quite sure
what's broken here (or rather how you came across it)...is there a bug filed
for this?
> - Mike
> > OK. I think the behavior Im seeing is due to 2 errors:
> > - the new quote logic (from Ben) was (inadvertently, I think) dropped
> > out of trunk at rev 2989
> > - the new quote logic itself has an error, in that instead of quoting
> > a zero-length argument as \"\" it instead inserts nothing into the
> > arguments= line for this case. For the examples Ive seen, this *seems*
> > to cause no harm, and was enabling jobs to run. I think its incorrect,
> > though.
> > I will put this back in trunk, test on Condor-G, and report back.
> > - Mike
> > > On Thu, 2011-01-13 at 11:37 -0600, Michael Wilde wrote:
> > > > I updated the ReleasePlans page with the checkout procedure that I
> > > > used.
> > > >   http://www.ci.uchicago.edu/wiki/bin/view/SWFT/ReleasePlans
> > > > Could everyone verify that this is correct:
> > > > svn co
> https://cogkit.svn.sourceforge.net/svnroot/cogkit/branches/4.1.8/src/cog
> > > > cd cog/modules
> > > > svn co https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.92
> > > > swift
> > > > cd swift
> > > > ant redist
> > > This is correct.
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110116/d82bd43a/attachment.html>
