[Swift-devel] Re: provider staging stage-in rate on localhost and PADS
Allan Espinosa aespinosa at cs.uchicago.edu
Sun Jan 16 19:38:31 CST 2011
So for the measurement interface, are you measuring the total data received as
the data arrives or when the received file is completely written to the job
directory.
I was measuring from the logs from JOB_START to JOB_END. I assumed the actualy
job execution to be 0. The 7MB/s probably corresponds to Mihael's stage out
results.  the cat jobs dump to stdout (redirected to a file in the swift
wrapper) probably shows the same behavior as the stageout.
-Allan
2011/1/16 Michael Wilde <wilde at mcs.anl.gov>:
> Mihael,
> If I follow this right, your stageout rate (7MB/sec) is about what Allan saw
> for stage ins (~ 6MB/sec as I recall).
> But your stagein rate is 59MB/sec and 73MB/sec depending on the mode (file vs
> proxy).
> So that does not yet replicate what he's seeing (on the WAN).
> Allan, I cant recall if you sent numbers for local-host tests?
yes. The rates are still at 5-7 MB/s
> - Mike
>> Right. So stageouts:
>> Progress: time:86039 Selecting site:231 Submitted:1 Active:8
>> Finished successfully:16
>> [IN]: Total transferred: 597.1 MB, current rate: 8.99 MB/s, average
>> rate: 7.02 MB/s
>> [OUT] Total transferred: 161.33 KB, current rate: 0 B/s, average rate:
>> 1.9 KB/s
>> That's probably because, as opposed to when the Java side reads files,
>> there is no read-ahead done by the worker. I'll see if I can add that.
>> On Sun, 2011-01-16 at 15:21 -0800, Mihael Hategan wrote:
>> > So I'm running some tests.
>> > So far here's how the stage-ins look like:
>> > -site: local (my laptop)
>> > -job input size: 32MB
>> > -256 jobs
>> > -job output size 0B
>> > -measurement is made at the interface between service and worker
>> > (the TCP connection). It is aggregated for all workers.
>> > -2 workers, 4 jobs per worker
>> > -this is the fast branch, but the job throughput is pretty
>> > irrelevant here since this is I/O bound.
>> > What I get is this:
>> > file:
>> > [IN]: Total transferred: 641.93 KB, current rate: 0 B/s, average rate:
>> > 4.62 KB/s
>> > [OUT] Total transferred: 8 GB, current rate: 40.2 MB/s, average rate:
>> > 58.92 MB/s
>> > Final status: time:140732 Finished successfully:256
>> > Time: 142.13, rate: 1 j/s
>> > proxy:
>> > Final status: time:113915 Finished successfully:256
>> > Time: 115.393, rate: 2 j/s
>> > [IN]: Total transferred: 705.62 KB, current rate: 6.44 KB/s, average rate:
>> > 6.24 KB/s
>> > [OUT] Total transferred: 8 GB, current rate: 36.08 MB/s, average
>> > rate:
>> > 72.54 MB/s
>> > (It is funny that proxy is faster than "file", but for now I'll
>> > ignore
>> > that).
>> > For comparison:
>> > mike at blabla2 coasters$ time dd if=/dev/zero of=~/tmp/8g bs=32KB
>> > count=262144
>> > 262144+0 records in
>> > 262144+0 records out
>> > 8388608000 bytes (8.4 GB) copied, 49.9836 s, 168 MB/s
>> > Things could be improved, but staging in does not seem to be the
>> > bottleneck.
>> > Next, stage-outs...
>> > Mihael
>> > On Wed, 2011-01-12 at 17:05 -0800, Mihael Hategan wrote:
>> > > On Wed, 2011-01-12 at 15:57 -0600, Daniel S. Katz wrote:
>> > > > As I read this, it appears that there is some limit in Swift,
>> > > > rather than in the hardware, that is causing these numbers to be
>> > > > very low.
>> > > > Mihael, do you agree?
>> > > Yes, but that does not exclude a limit in hardware in other
>> > > configurations.
>> > > >   Can you help us figure out what's going on?
>> > > Of course.
