[Swift-devel] Problem with 0.92 sending jobs to OSG via Condor-G
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jan 13 11:16:53 CST 2011
On Thu, 2011-01-13 at 08:45 -0600, Michael Wilde wrote:
> This is very strange. I diffed the entire cog and modules/swift dir trees between my 0.92 and trunk working copies. The only changes I see are:
> - my (one) local mod to remove Time:HiRes for Ranger in worker.pl
> - David's patch to override (which *does* touch JobSpecification, suspiciously!
> The latter I will investigate, but Im very surprised to see so few differences between 0.92 and a trunk working copy.
> Mihael, I *thought* you integrated changes from stable-branch ( ~
> 0.91) into the 0.92 branch. Or did you integrate those into trunk, and
> perhaps I took a later copy of trunk?  If you did indeed integrate the
> stable changes into trunk, *and* its possible that what I test on was
> not re-built after I did an svn update some time in the past few
> weeks, *then* perhaps the Condor bug crept in between recent changes
> to trunk.
I merged the 0.91 branch back to trunk. That might have gone wrong.
That's why it's relevant to do a diff between the version that works and
0.92.
