[Swift-devel] Errors compiling 0.92 with Java 1.5
David Kelly
dk0966 at cs.ship.edu
Wed Jan 12 19:58:49 CST 2011
I ran into a similar issue. Here is the patch I wrote for it (there
should also be a bug report)
On Wed, Jan 12, 2011 at 8:53 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> I get the errors below when I build 0.92 with this Java and ant on RENCI engage-submit:
> e$ which java
> /opt/osg/1.0.0/jdk1.5/bin/java
> e$ java -version
> java version "1.5.0_14"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_14-b03)
> Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_14-b03, mixed mode)
> e$ which javac
> /opt/osg/1.0.0/jdk1.5/bin/javac
> e$ ant -version
> Apache Ant version 1.6.5 compiled on June 2 2005
> e$
> The same svn rev seems to uild clean with 1.6 on PADS.
> I dont think this necessarily needs to be fixed; but at least documented if we no longer work with 1.5. (I recall we said we wont support 1.4 -- or was that 1.5?)
> - Mike
> Errors:
> compile:
> [echo] [util]: COMPILE
> [mkdir] Created dir: /home/wilde/swift/src/0.92/cog/modules/util/build
> [javac] Compiling 53 source files to /home/wilde/swift/src/0.92/cog/modules/util/build
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:71: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:105: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:144: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:227: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:232: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:237: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:242: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:247: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:252: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:257: method does not override a method from its superclass
> [javac] @Override
> [javac] ^
> [javac] Note: Some input files use or override a deprecated API.
> [javac] Note: Recompile with -Xlint:deprecation for details.
> [javac] Note: Some input files use unchecked or unsafe operations.
> [javac] Note: Recompile with -Xlint:unchecked for details.
> [javac] 10 errors
> BUILD FAILED
> /home/wilde/swift/src/0.92/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:444: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:79: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:52: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/swift/dependencies.xml:4: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:163: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:168: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/karajan/build.xml:59: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/karajan/dependencies.xml:4: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/abstraction/build.xml:58: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/abstraction/dependencies.xml:4: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/abstraction-common/build.xml:63: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/abstraction-common/dependencies.xml:7: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/modules/util/build.xml:59: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:465: The following error occurred while executing this line:
> /home/wilde/swift/src/0.92/cog/mbuild.xml:228: Compile failed; see the compiler error output for details.
> Total time: 20 seconds
> e$ which java
> e$ java -version
> e$ cd
> e$ ls
> bin ftdock glenslogs.tar.gz osgcat.sh osgfact out.ps out.qstat swift t1.stderr t1.sub t2.sub
> buildnrun.sh glasslogs.tgz mygroup osgcat.sh~ out out.ps2 pfgroup t1.log t1.stdout t1.sub~
> e$ which javac
> e$ ant -version
> e$
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110112/13c8ad0e/attachment.bin>
