[Swift-devel] Errors compiling 0.92 with Java 1.5
Michael Wilde
wilde at mcs.anl.gov
Wed Jan 12 19:53:54 CST 2011
I get the errors below when I build 0.92 with this Java and ant on RENCI engage-submit:
e$ which java
/opt/osg/1.0.0/jdk1.5/bin/java
e$ java -version
java version "1.5.0_14"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_14-b03)
Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_14-b03, mixed mode)
e$ which javac
/opt/osg/1.0.0/jdk1.5/bin/javac
e$ ant -version
Apache Ant version 1.6.5 compiled on June 2 2005
e$
The same svn rev seems to uild clean with 1.6 on PADS.
I dont think this necessarily needs to be fixed; but at least documented if we no longer work with 1.5. (I recall we said we wont support 1.4 -- or was that 1.5?)
- Mike
Errors:
compile:
[echo] [util]: COMPILE
[mkdir] Created dir: /home/wilde/swift/src/0.92/cog/modules/util/build
[javac] Compiling 53 source files to /home/wilde/swift/src/0.92/cog/modules/util/build
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:71: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:105: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:144: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:227: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:232: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:237: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:242: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:247: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:252: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:257: method does not override a method from its superclass
[javac] @Override
[javac] ^
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 10 errors
BUILD FAILED
/home/wilde/swift/src/0.92/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:444: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:79: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:52: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/swift/dependencies.xml:4: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:163: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:168: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/karajan/build.xml:59: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/karajan/dependencies.xml:4: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/abstraction/build.xml:58: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/abstraction/dependencies.xml:4: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/abstraction-common/build.xml:63: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/abstraction-common/dependencies.xml:7: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/modules/util/build.xml:59: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:465: The following error occurred while executing this line:
/home/wilde/swift/src/0.92/cog/mbuild.xml:228: Compile failed; see the compiler error output for details.
Total time: 20 seconds
e$ which java
e$ java -version
e$ cd
e$ ls
bin ftdock glenslogs.tar.gz osgcat.sh osgfact out.ps out.qstat swift t1.stderr t1.sub t2.sub
buildnrun.sh glasslogs.tgz mygroup osgcat.sh~ out out.ps2 pfgroup t1.log t1.stdout t1.sub~
e$ which javac
e$ ant -version
e$
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
