[Swift-devel] Re: devel prios for Mihael
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jan 11 19:10:57 CST 2011
On Tue, 2011-01-11 at 17:15 -0600, Michael Wilde wrote:
> Consolidating what we discussed on the list into an update on these issues:
> > - support Allan to achieve ExTENCI data transfer goals
> This is two issues:
> HIGH: 1. coasters fails at ~ >60 workers per service
> ^^^ bubbles up to higher prio
> HIGH: 2. throughput w/ provider staging is about 2jobs/sec/service with 3MB data input file per job.  Allan needs at least 10 jobs/sec/service for ExTENCI runs.
Right. I need to look at these.
> Its possible that issue #2 is the same as the next issue below, "coaster time gap issue".
> ^^^ Justin and Allan are both working to isolate this at the moment.
> > - assess coaster time gap issue with Justin; fix if needed
I am not familiar with this.
> > - add option to set coaster-service to passive mode
> - low prio. Is its trivial to add?
What is this?
