[Swift-devel] Fwd: poor performance
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jan 11 17:33:57 CST 2011
Marc confirms that he was using an un-fixed release. Im building an 0.92 on engage submit now.
If you have suggestions on score/throttle values to accelerate the scheduler's default ramp up, would be good to try (in addition to a test of the defaults).
- Mike
----- Forwarded Message -----
To: "Michael Wilde" <wilde at mcs.anl.gov>
Sent: Tuesday, January 11, 2011 5:28:37 PM
Subject: Re: poor performance
Hi Mike,
> Can you confirm that you did *not* build this yourself, and that the latest run is still on the old, un-fixed Swift release?
I ain't building that :-D  So I must be using the one in your renci account:
/home/wilde/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/
> - change your throttle and score values to something lower than 1,10000 (which we will need some advice from Mihael on). I suggested we try the new code with the throttles removed.
You already suggest to remove them...
> So while I wait to hear from you I will build Swift 0.92 on engage. And also start setting up for running on OSG form the CI network instead of engage-submit.
alright,
  A+
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
