[Swift-devel] branching for stabilization of release .95
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jan  6 14:52:02 CST 2011
Sarah, it would be great if in the process of release building you can start a wiki page to capture the tools and techniques. :)
Mike
----- Original Message -----
> On Thu, 2011-01-06 at 11:30 -0800, Sarah Kenny wrote:
> > it was revision 2991...but looks like you and justin added some
> > things
> > before you branched again so i guess no harm. i'm a bit surprised
> > that
> > didn't give you an error from svn though.
> That explains it!
> I was wondering why the branch looked like 4.1.8/current/src instead
> of
> what I was expecting (4.1.8/src). I thought I mistyped something and I
> deleted it and rebranched. Sorry.
> In any event, attached are a couple of scripts I use for this. You may
> find them useful in the future.
> Mihael
> > On Thu, Jan 6, 2011 at 11:06 AM, Sarah Kenny <skenny at uchicago.edu>
> > wrote:
> >         ummm....i branched 4.1.8 when i did the swift branch (?)
> >         On Thu, Jan 6, 2011 at 10:50 AM, Mihael Hategan
> >         <hategan at mcs.anl.gov> wrote:
> >                 I also branched cog to 4.1.8. Skenny, you should
> >                 probably have write
> >                 access to the cog svn.
> >                 On Mon, 2011-01-03 at 21:45 -0800, Sarah Kenny
> >                 wrote:
> >                 > alrighty...branching done :)
> >                 > On Mon, Jan 3, 2011 at 9:18 PM, Mihael Hategan
> >                 > wrote:
> >                 >         Sorry about that. Swift trunk/r3837.
> >                 >         On Mon, 2011-01-03 at 21:09 -0800, Sarah
> >                 Kenny wrote:
> >                 >         > still getting some complaints from the
> >                 compiler on the
> >                 >         merged files:
> >                 >         > compile:
> >                 >         >      [echo] [swift]: COMPILE
> >                 >         >     [javac] Compiling 374 source files
> >                 to /home/skenny/builds/cog/modules/swift/build
> >                 [javac]
> >                 /home/skenny/builds/cog/modules/swift/src/org/griphyn/vdl/mapping/AbstractDataNode.java:557:
> >                 closeArraySizes() is already defined in
> >                 org.griphyn.vdl.mapping.AbstractDataNode
> >                 >         >     [javac] public void
> >                 closeArraySizes() {
> >                 >         >     [javac] ^
> >                 >         >     [javac] Note: Some input files use
> >                 unchecked or unsafe
> >                 >         operations.
> >                 >         >     [javac] Note: Recompile with
> >                 -Xlint:unchecked for
> >                 >         details.
> >                 >         >     [javac] 1 error
> >                 >         > BUILD FAILED
> >                 >         > On Mon, Jan 3, 2011 at 1:37 PM, Mihael
> >                 Hategan
> >                 >         > wrote:
> >                 >         >         Should be fixed in cog
> >                 >         >         trunk/2990.
> >                 >         >         On Mon, 2011-01-03 at 04:35
> >                 >         >         -0600,
> >                 Mihael Hategan
> >                 >         wrote:
> >                 >         >         > I'll fix that tomorrow.
> >                 >         >         > Actually
> >                 that's later
> >                 >         today.
> >                 >         >         > Mihael
> >                 >         >         > On Sun, 2011-01-02 at 20:23
> >                 -0800, Sarah Kenny
> >                 >         wrote:
> >                 >         >         > > sorry, forgot where we
> >                 >         >         > > landed
> >                 on the naming...as
> >                 >         long as
> >                 >         >         it's
> >                 >         >         > > somewhere btwn .91 and 1.0
> >                 >         >         > > we
> >                 should be all
> >                 >         right :) but
> >                 >         >         yeah, i can
> >                 >         >         > > branch the release as .92.
> >                 however, i just
> >                 >         checked out
> >                 >         >         trunk and am
> >                 >         >         > > getting some errors
> >                 >         >         > > compiling:
> >                 >         >         > > compile:
> >                 >         >         > >      [echo]
> >                 [provider-coaster]: COMPILE
> >                 >         >         > >     [javac] Compiling 124
> >                 source files
> >                 to
> >                 /home/skenny/builds/cog/modules/provider-coaster/build
> >                 [javac]
> >                 /home/skenny/builds/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java:242:
> >                 illegal start of type
> >                 >         >         > >     [javac] if
> >                 (shutdown) {
> >                 >         >         > >     [javac] ^
> >                 [javac]
> >                 ';' expected
> >                 >         >         > >     [javac] if
> >                 (shutdown) {
> >                 >         >         > >     [javac] ^
> >                 [javac]
> >                 not a statement
> >                 >         >         > >     [javac] if
> >                 (shutdown) {
> >                 >         >         > >     [javac] ^
> >                 [javac]
> >                 ';' expected
> >                 >         >         > >     [javac] if
> >                 (shutdown) {
> >                 >         >         > >     [javac]
> >                 >         >         > >     [javac] 4 errors
> >                 >         >         > > p.s. happy new year to you
> >                 too!
> >                 >         >         > > On Sun, Jan 2, 2011 at 5:20
> >                 PM, Michael Wilde
> >                 >         >         <wilde at mcs.anl.gov>
> >                 >         >         > > wrote:
> >                 >         >         > >         Indeed - that was
> >                 >         >         > >         the
> >                 "great" part :)
> >                 >         >         > >         I was just asking so
> >                 we that we get the
> >                 >         release
> >                 >         >         number right
> >                 >         >         > >         when we create the
> >                 release branch.
> >                 >         >         > >         - Mike
> >                 >         >         > >         ----- Original
> >                 >         >         > >         Message
> >                 >         >         > >         > On Sun, 2011-01-02
> >                 at 16:46 -0600,
> >                 >         Michael Wilde
> >                 >         >         wrote:
> >                 >         >         > >         > > Happy New Year,
> >                 All!
> >                 >         >         > >         > And to you, too!
> >                 >         >         > >         > > This sounds
> >                 >         >         > >         > > great,
> >                 but wasn't the
> >                 >         plan to call
> >                 >         >         the current
> >                 >         >         > >         stable
> >                 >         >         > >         > > branch 0.91 and
> >                 the current trunk
> >                 >         0.92?
> >                 >         >         > >         > Irrespective of
> >                 that, bug fixes from
> >                 >         the branch
> >                 >         >         should be
> >                 >         >         > >         merged to
> >                 >         >         > >         > trunk. And better
> >                 >         >         > >         > to
> >                 do so before
> >                 >         trunk is
> >                 >         >         branched into
> >                 >         >         > >         another
> >                 >         >         > >         > release
> >                 >         >         > >         > branch.
> >                 >         >         > >         > Mihael
> >                 >         >         > >         Michael Wilde
> >                 >         >         > >         Computation
> >                 >         >         > >         Institute,
> >                 University of
> >                 >         Chicago
> >                 >         >         > >         Mathematics and
> >                 Computer Science
> >                 >         Division
> >                 >         >         > >         Argonne National
> >                 Laboratory
> >                 _______________________________________________
> >                 >         >         > Swift-devel mailing list
> >                 >         >         > Swift-devel at ci.uchicago.edu
> >                 http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
