[Swift-devel] branching for stabilization of release .95
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jan  6 14:44:18 CST 2011
On Thu, 2011-01-06 at 11:30 -0800, Sarah Kenny wrote:
> it was revision 2991...but looks like you and justin added some things
> before you branched again so i guess no harm. i'm a bit surprised that
> didn't give you an error from svn though.
That explains it!
I was wondering why the branch looked like 4.1.8/current/src instead of
what I was expecting (4.1.8/src). I thought I mistyped something and I
deleted it and rebranched. Sorry.
In any event, attached are a couple of scripts I use for this. You may
find them useful in the future.
Mihael
> On Thu, Jan 6, 2011 at 11:06 AM, Sarah Kenny <skenny at uchicago.edu>
> wrote:
>         ummm....i branched 4.1.8 when i did the swift branch (?)
>         On Thu, Jan 6, 2011 at 10:50 AM, Mihael Hategan
>         <hategan at mcs.anl.gov> wrote:
>                 I also branched cog to 4.1.8. Skenny, you should
>                 probably have write
>                 access to the cog svn.
>                 On Mon, 2011-01-03 at 21:45 -0800, Sarah Kenny wrote:
>                 > alrighty...branching done :)
>                 > On Mon, Jan 3, 2011 at 9:18 PM, Mihael Hategan
>                 > wrote:
>                 >         Sorry about that. Swift trunk/r3837.
>                 >         On Mon, 2011-01-03 at 21:09 -0800, Sarah
>                 Kenny wrote:
>                 >         > still getting some complaints from the
>                 compiler on the
>                 >         merged files:
>                 >         > compile:
>                 >         >      [echo] [swift]: COMPILE
>                 >         >     [javac] Compiling 374 source files
>                 to /home/skenny/builds/cog/modules/swift/build
>                 [javac] /home/skenny/builds/cog/modules/swift/src/org/griphyn/vdl/mapping/AbstractDataNode.java:557: closeArraySizes() is already defined in org.griphyn.vdl.mapping.AbstractDataNode
>                 >         >     [javac]     public void
>                 closeArraySizes() {
>                 >         >     [javac]                 ^
>                 >         >     [javac] Note: Some input files use
>                 unchecked or unsafe
>                 >         operations.
>                 >         >     [javac] Note: Recompile with
>                 -Xlint:unchecked for
>                 >         details.
>                 >         >     [javac] 1 error
>                 >         > BUILD FAILED
>                 >         > On Mon, Jan 3, 2011 at 1:37 PM, Mihael
>                 Hategan
>                 >         > wrote:
>                 >         >         Should be fixed in cog trunk/2990.
>                 >         >         On Mon, 2011-01-03 at 04:35 -0600,
>                 Mihael Hategan
>                 >         wrote:
>                 >         >         > I'll fix that tomorrow. Actually
>                 that's later
>                 >         today.
>                 >         >         > Mihael
>                 >         >         > On Sun, 2011-01-02 at 20:23
>                 -0800, Sarah Kenny
>                 >         wrote:
>                 >         >         > > sorry, forgot where we landed
>                 on the naming...as
>                 >         long as
>                 >         >         it's
>                 >         >         > > somewhere btwn .91 and 1.0 we
>                 should be all
>                 >         right :) but
>                 >         >         yeah, i can
>                 >         >         > > branch the release as .92.
>                 however, i just
>                 >         checked out
>                 >         >         trunk and am
>                 >         >         > > getting some errors compiling:
>                 >         >         > > compile:
>                 >         >         > >      [echo]
>                 [provider-coaster]: COMPILE
>                 >         >         > >     [javac] Compiling 124
>                 source files
>                 to /home/skenny/builds/cog/modules/provider-coaster/build
>                 [javac] /home/skenny/builds/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java:242: illegal start of type
>                 >         >         > >     [javac]             if
>                 (shutdown) {
>                 >         >         > >     [javac]             ^
>                 [javac] /home/skenny/builds/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java:242: ';' expected
>                 >         >         > >     [javac]             if
>                 (shutdown) {
>                 >         >         > >     [javac]               ^
>                 [javac] /home/skenny/builds/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Cpu.java:242: not a statement
>                 >         >         > >     [javac]             if
>                 (shutdown) {
>                 >         >         > >     [javac]                 ^
>                 >         >         > >     [javac]             if
>                 (shutdown) {
>                 >         >         > >     [javac]
>                 >         >         > >     [javac] 4 errors
>                 >         >         > > p.s. happy new year to you
>                 too!
>                 >         >         > > On Sun, Jan 2, 2011 at 5:20
>                 PM, Michael Wilde
>                 >         >         <wilde at mcs.anl.gov>
>                 >         >         > > wrote:
>                 >         >         > >         Indeed - that was the
>                 "great" part :)
>                 >         >         > >         I was just asking so
>                 we that we get the
>                 >         release
>                 >         >         number right
>                 >         >         > >         when we create the
>                 release branch.
>                 >         >         > >         - Mike
>                 >         >         > >         ----- Original Message
>                 >         >         > >         > On Sun, 2011-01-02
>                 at 16:46 -0600,
>                 >         Michael Wilde
>                 >         >         wrote:
>                 >         >         > >         > > Happy New Year,
>                 All!
>                 >         >         > >         > And to you, too!
>                 >         >         > >         > > This sounds great,
>                 but wasn't the
>                 >         plan to call
>                 >         >         the current
>                 >         >         > >         stable
>                 >         >         > >         > > branch 0.91 and
>                 the current trunk
>                 >         0.92?
>                 >         >         > >         > Irrespective of
>                 that, bug fixes from
>                 >         the branch
>                 >         >         should be
>                 >         >         > >         merged to
>                 >         >         > >         > trunk. And better to
>                 do so before
>                 >         trunk is
>                 >         >         branched into
>                 >         >         > >         another
>                 >         >         > >         > release
>                 >         >         > >         > branch.
>                 >         >         > >         > Mihael
>                 >         >         > >         Michael Wilde
>                 >         >         > >         Computation Institute,
>                 University of
>                 >         Chicago
>                 >         >         > >         Mathematics and
>                 Computer Science
>                 >         Division
>                 >         >         > >         Argonne National
>                 Laboratory
>                 _______________________________________________
>                 >         >         > Swift-devel mailing list
>                 >         >         > Swift-devel at ci.uchicago.edu
>                 http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Type: application/x-shellscript
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110106/4c8c0310/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110106/4c8c0310/attachment-0001.bin>
