[Swift-devel] [Bug 257] New: Race condition in Swiftscript execution
bugzilla-daemon at mcs.anl.gov
Wed Feb 16 13:54:16 CST 2011
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=257
Summary: Race condition in Swiftscript execution
Product: Swift
Version: unspecified
Platform: PC
OS/Version: Linux
Status: NEW
Severity: normal
Priority: P2
Component: General
AssignedTo: hategan at mcs.anl.gov
ReportedBy: tim.g.armstrong at gmail.com
Created an attachment (id=289)
--> (http://bugzilla.mcs.anl.gov/swift/attachment.cgi?id=289)
Swift script and Swift logs for passing and failing cases.
I am running:
Swift svn swift-r4087 cog-r3051
I have come across a race condition in a script that I have been using for a
while. . What it does is launches a dummy job (to ensure everything is started
up), then sits in a serial loop, acting as a server listening on a named pipe
for tasks to execute.
Every 5 or so times the script runs, the dummy jobs completes but the script
it fails to even enter into the loop. I have attached logs for both the usual
(correct) behaviour, and the race condition. The side-by-side diff at the
bottom illustrates clearly where the behaviour diverges.
= rserver.swift ============================================================
type file;
type RData;
app (external e, RData result, file stout, file sterr) runR (file shellscript,
file RServerScript, RData rcall)
bash @shellscript @RServerScript @rcall @result stdout=@stout stderr=@sterr;
app ack (external e[])
bashlocal "-c" @strcat("echo done > ",resultPipeName);
app passivate ()
bash "-c" "echo dummy swift job;";
(external e[]) apply (string runDir)
RData rcalls[] <simple_mapper; location=runDir, prefix="cbatch.",
suffix=".Rdata", padding=0>;
RData results[] <simple_mapper; location=runDir, prefix="rbatch.",
file stout[] <simple_mapper; location=runDir, prefix="stdout.",
suffix=".txt", padding=0>;
file sterr[] <simple_mapper; location=runDir, prefix="stderr.",
file runRscript <"EvalRBatchPersistent.sh">;
file rsScript <"SwiftRServer.R">;
foreach c, i in rcalls {
(e[i], results[i],stout[i], sterr[i]) = runR(runRscript,rsScript,c);
passivate();
string pipedir = @arg("pipedir");
global string requestPipeName = @strcat(pipedir,"/requestpipe");
global string resultPipeName = @strcat(pipedir,"/resultpipe");
iterate serially {
boolean done;
string dir;
dir = readData(requestPipeName); # Reads direct from this local pipe. Assumes
Swift started in right dir.
external wait[];
wait = apply(dir);
if (dir=="done") { done=true; } else { done=false;}
fprintf(resultPipeName, "%kdone\n", wait);
} until (done);
= sidebyside ============================================================
Loader Max heap: 238616576 Loader Max heap: 238616576
Loader rserver.swift: source file is new. Recompiling. Loader
Karajan Validation of XML intermediate file was successful Karajan
VDL2ExecutionContext Stack dump: VDL2ExecutionContext Stack
dump:
iB = 0, bA = false, bB = false] iB = 0, bA = false, bB = false]
configuration [cf] configuration [cf]
unknown Using sites file: sites.xml unknown Using sites file:
sites.xml
unknown Using tc.data: tc unknown Using tc.data: tc
AbstractScheduler Setting resources to: {local3=local3, fork=
unknown Swift svn swift-r4087 cog-r3051 unknown Swift svn
unknown RUNID id=run:20110216-1244-7l6y6irf | unknown RUNID
id=run:20110216-1246-vfu3jq4c
VDLFunction FUNCTION: arg() VDLFunction FUNCTION: arg()
SetFieldValue Set: pipedir=/tmp/tga/SwiftR/swift.1237 |
SetFieldValue Set: pipedir=/tmp/tga/SwiftR/swift.1447
> SetFieldValue Set:
requestPipeName=/tmp/tga/SwiftR/swift.1447
> SetFieldValue Set:
resultPipeName=/tmp/tga/SwiftR/swift.1447/
vdl:execute START thread=0-0 tr=bash vdl:execute START
thread=0-0 tr=bash
WeightedHostScoreScheduler CONTACT_SELECTED host=local0, scor <
apply STARTCOMPOUND thread=0-4-0-1 name=apply apply STARTCOMPOUND
> SetFieldValue Set: done=false
CONTACT_SELECTED host=local3, scor
GlobalSubmitQueue No global submit throttle set. Using defaul
LateBindingScheduler JobQueue: 0 LateBindingScheduler JobQueue:
0
LateBindingScheduler JobQueue: 0 | AbstractDataNode Found
data org.griphyn.vdl.mapping.RootDataN
vdl:initshareddir START host=local0 - Initializing shared dir |
AbstractDataNode Found data org.griphyn.vdl.mapping.RootDataN
AbstractDataNode Found data org.griphyn.vdl.mapping.RootDataN <
SetFieldValue Set: swift#mapper#17003=cbatch. SetFieldValue Set:
SetFieldValue Set: swift#mapper#17005=.Rdata SetFieldValue Set:
SetFieldValue Set: swift#mapper#17007=0 SetFieldValue Set:
SetFieldValue Set: swift#mapper#17008=rbatch. SetFieldValue Set:
SetFieldValue Set: swift#mapper#17010=.Rdata SetFieldValue Set:
SetFieldValue Set: swift#mapper#17011=0 <
SetFieldValue Set: swift#mapper#17012=stdout. SetFieldValue Set:
SetFieldValue Set: swift#mapper#17014=.txt SetFieldValue Set:
SetFieldValue Set: swift#mapper#17016=0 | SetFieldValue Set:
swift#mapper#17020=0
SetFieldValue Set: swift#mapper#17017=stderr. SetFieldValue Set:
SetFieldValue Set: swift#mapper#17019=.txt SetFieldValue Set:
SetFieldValue Set: swift#mapper#17020=0 | SetFieldValue Set:
rcalls.$[]/1.[1]
> vdl:initshareddir START host=local3 -
> vdl:execute START thread=0-4-0-1-12-0-1
tr=bash
CONTACT_SELECTED host=local1, scor
> vdl:initshareddir START host=local1 -
0
0
0
0
0
vdl:initshareddir END host=local0 - Done initializing shared <
vdl:createdirset START jobid=bash-dls6916k host=local0 - Init <
vdl:createdirset END jobid=bash-dls6916k - Done initializing <
vdl:dostagein START jobid=bash-dls6916k - Staging in files <
vdl:dostagein END jobid=bash-dls6916k - Staging in finished <
GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity= <
JobSubmissionTaskHandler Submit: in: /tmp/tga/SwiftR/swift.12 <
0
vdl:dostageout START jobid=bash-dls6916k - Staging out files |
vdl:dostageout END jobid=bash-dls6916k - Staging out finished |
vdl:initshareddir END host=local1 - Done initializing shared
> vdl:initshareddir END host=local3 - Done
initializing shared
jobid=bash-nq2a916k host=local3 - Init
> vdl:createdirset END jobid=bash-nq2a916k
- Done initializing
> vdl:dostagein START jobid=bash-nq2a916k
- Staging in files
jobid=bash-mq2a916k host=local1 - Init
> vdl:dostagein END jobid=bash-nq2a916k -
Staging in finished
> vdl:createdirs START
path=tmp/tga/SwiftR/requests.P31228/R000
> vdl:createdirset END jobid=bash-mq2a916k
- Done initializing
> vdl:dostagein START jobid=bash-mq2a916k
- Staging in files
> vdl:dostagein END jobid=bash-mq2a916k -
Staging in finished
> vdl:dostageout START jobid=bash-nq2a916k
- Staging out files
> vdl:dostageout END jobid=bash-nq2a916k -
0
vdl:execute END_SUCCESS thread=0-0 tr=bash vdl:execute END_SUCCESS
thread=0-0 tr=bash
> vdl:dostageout START jobid=bash-mq2a916k
- Staging out files
> LateBindingScheduler JobQueue: 1
> vdl:dostageout END jobid=bash-mq2a916k -
thread=0-4-0-1-12-0-1 tr=bash
> apply ENDCOMPOUND thread=0-4-0-1
> apply STARTCOMPOUND thread=0-4-1-1
name=apply
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
> SetFieldValue Set:
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the assignee of the bug.
