[Swift-devel] Proposed sites.xml management for 0.92 release
    Sarah Kenny
    skenny at uchicago.edu
    Mon Feb 14 10:37:11 CST 2011
sounds good to me david...i don't know perl so maybe my time would be better
spent using it and updating the doc in sync with you working on the code (?)
i think first we want to separate swiftconfig from swiftrun...it would be
good if users who are already used to running regular 'swift' to be able to
transition to using swiftconfig (i realize this probably affects the doc
more than your code, i just wanted to mention it).
so, maybe the first step is switching out the sites templates?
On Fri, Feb 11, 2011 at 8:51 PM, David Kelly <dk0966 at cs.ship.edu> wrote:
> Would it be easier to modify the existing swiftconfig to adjust to the new
> format of templates?
> The main steps that were outlined are nearly already completed with
> swiftconfig
> - The commands are already there
> - A set of templates already exists, but would most likely be replaced with
> the ones verified by automated testing in the format Justin specified
> - A good start for documentation using swiftconfig on a variety of
> configurations is at
> http://www.ci.uchicago.edu/wiki/bin/view/SWFT/LearningSwift
> - Documentation for commands and syntax is there, swiftconfig -h and
> swiftrun -h
> - List all templates with swiftconfig -list templates (already knows the
> correct order of where to look for templates)
> - Help for specific templates is a good idea. That would be pretty
> straightforward to add
> - Support for applications and application groups is already there
> If we started over it seems like we would be duplicating a lot of code
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110214/054109d2/attachment.html>
