[Swift-devel] Proposed sites.xml management for 0.92 release
    David Kelly
    dk0966 at cs.ship.edu
    Fri Feb 11 22:51:19 CST 2011
Would it be easier to modify the existing swiftconfig to adjust to the new
format of templates?
The main steps that were outlined are nearly already completed with
swiftconfig
- The commands are already there
- A set of templates already exists, but would most likely be replaced with
the ones verified by automated testing in the format Justin specified
- A good start for documentation using swiftconfig on a variety of
configurations is at
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/LearningSwift
- Documentation for commands and syntax is there, swiftconfig -h and
swiftrun -h
- List all templates with swiftconfig -list templates (already knows the
correct order of where to look for templates)
- Help for specific templates is a good idea. That would be pretty
straightforward to add
- Support for applications and application groups is already there
If we started over it seems like we would be duplicating a lot of code
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110211/9cd649da/attachment.html>
