[Swift-devel] Swift trunk broken?
Tim Armstrong tim.g.armstrong at gmail.com
Mon Feb 7 16:33:33 CST 2011
I've run into a different problem...
Swift fails with the following exception:
Execution failed:
        java.lang.NullPointerException
        at org.globus.cog.karajan.Optimizer.optimize0(Optimizer.java:36)
        at org.globus.cog.karajan.Optimizer.optimize(Optimizer.java:28)
        at
org.globus.cog.karajan.util.serialization.XMLConverter.read(XMLConverter.java:207)
        at
org.globus.cog.karajan.util.serialization.XMLConverter.read(XMLConverter.java:192)
        at
org.globus.cog.karajan.workflow.nodes.ExecuteFile.post(ExecuteFile.java:128)
        at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
        at
org.globus.cog.karajan.workflow.nodes.ExecuteFile.completed(ExecuteFile.java:155)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
        at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
        at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
        at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
        at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
        at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
        at
org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
        at
org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
        at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
        at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
        at
java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
        at java.util.concurrent.FutureTask.run(FutureTask.java:138)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:619)
Time: 0.535, rate: 30624 j/s
Nothing really appears in the logs:
2011-02-07 16:32:22,668-0600 DEBUG Loader Loader started
- Tim
On Mon, Feb 7, 2011 at 12:54 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Should be fixed now.
> On Mon, 2011-02-07 at 10:03 -0800, Mihael Hategan wrote:
> > Ooops. I didn't get any emails over the weekend (well, it seems I did,
> > but my otherwise reliable email notification didn't work). So I'm a bit
> > behind.
> > Mihael
> > On Fri, 2011-02-04 at 14:44 -0600, Michael Wilde wrote:
> > > Im getting strange errors from trunk at the moment from previously
> working scripts. Seemed to be unable to parse sites.xml.
> > > In the process of debugging this, I find that I cant get the simplest
> of swift scripts (a single trace statement) to run.
> > > Is anyone else encountering similar problems?
> > > Here's what I get:
> > > com$ cat hi.swift
> > > trace("hi");
> > > com$ java -version
> > > java version "1.6.0_20"
> > > Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
> > > Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
> > > com$ swift -version
> > > Swift svn swift-r4061 cog-r3046
> > > com$ swift hi.swift
> > > RunID: 20110204-1439-j430gp9g
> > > Progress:  time:0
> > > Execution failed:
> > >         1 names specified; 0 arguments found
> > > Time: 1.179, rate: 13896 j/s
> > > com$ cat hi.xml
> > > <program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
> > >          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > >          xmlns:xs="http://www.w3.org/2001/XMLSchema">
> > >   <call proc="trace" src="line 1">
> > >     <input><stringConstant>hi</stringConstant></input>
> > >   </call>
> > > </program>
> > > com$
> > > com$ cat *9g.log
> > > 2011-02-04 14:39:29,205-0600 DEBUG Loader Max heap: 238616576
> > > 2011-02-04 14:39:29,206-0600 DEBUG Loader kmlversion is
> >a1ce0de8-81e9-4226-987a-0bbcb40af008<
> > > 2011-02-04 14:39:29,207-0600 DEBUG Loader build version is
> > > 2011-02-04 14:39:29,207-0600 DEBUG Loader Recompilation suppressed.
> > > 2011-02-04 14:39:29,343-0600 INFO  VDL2ExecutionContext Stack dump:
> > > Level 1
> > > [iA = 0, iB = 0, bA = false, bB = false]
> > >         vdl:instanceconfig = Swift configuration []
> > >         vdl:operation = run
> > >         swift.home = /home/wilde/swift/rev/trunk/bin/..
> > >         PATH_SEPARATOR = /
> > > 2011-02-04 14:39:29,900-0600 INFO  unknown Using sites file:
> /home/wilde/swift/rev/trunk/bin/../etc/sites.xml
> > > 2011-02-04 14:39:29,928-0600 INFO  unknown Using tc.data:
> /home/wilde/swift/rev/trunk/bin/../etc/tc.data
> > > 2011-02-04 14:39:30,023-0600 INFO  AbstractScheduler Setting resources
> to: {localhost=localhost}
> > > 2011-02-04 14:39:30,468-0600 INFO  unknown Swift svn swift-r4061
> cog-r3046
> > > 2011-02-04 14:39:30,469-0600 INFO  unknown RUNID
> id=run:20110204-1439-j430gp9g
> > > 2011-02-04 14:39:30,511-0600 DEBUG VDL2ExecutionContext 1 names
> > >         at
> org.globus.cog.karajan.workflow.nodes.SetVar.post(SetVar.java:43)
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > > 2011-02-04 14:39:30,522-0600 INFO  ExecutionContext Detailed exception:
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > >         at
> > > 2011-02-04 14:39:30,522-0600 INFO  Loader Swift finished with errors
> > > com$
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110207/55d6a26e/attachment.html>
